So Im building a half-new system...any ideas?
Well, my computer kinda sucks at the moment so I want to replace my mobo, video card, ram, and processor...
my current specs are as follows:
Mobo - Asus A8NE 939 motherboard
Video card - Nvidia GeForce 6800 XT 256mb
RAM - 1GB pc3200 dual channel
CPU - AMD Athlon 64 3200+
HDD - 2 x Maxtor DiamondMax 80gb RAID 0
and the 500w power supply that came with the case
I was thinking about changing that to these parts (only one vid card at first tho)
Mobo - BIOSTAR TForce TP45HP LGA 775 Intel P45 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138123 $109.99 or...
ASRock X38TurboTwins LGA 775 Intel X38 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157136 $159.99
Video Card(s) - SAPPHIRE 100225DDR3L Radeon HD 3870 512MB 256-bit GDDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102752 $99.99 x2= $200.00
CPU - Intel Core 2 Duo E8400 Wolfdale 3.0GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037 $169.99
RAM - 2X OCZ Platinum 2GB (4 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227178 $112.00
Is this a good idea or have I got it all wrong?
2 answers Last reply
More about building half system ideas
  1. oh yea...I also have plans to get a new PSU eventually when I have the money....although I havent the foggiest what I should get
  2. instead of 2 3870's i would get 1 4850.
    get the p45
    and thats it, well new PSU would help if you ever wanted to CF the 4850's
New Build Graphics Cards Intel Systems Product
