I've got all the components chosen for my new system except the power supply. I would like to keep it under fifty dollars, but [erhaps this is unrealistic. I would certainly rather spend a bit extra for more dependability, but I am shooting for value with this system. The major components are as follows
Intel Core 2 Duo E7300
ASUS P5Q-VM LGA 775
OCZ SLI-Ready Dual Channel 4096MB PC6400 DDR2 800MHz Memory
Will be using a 80gb and 500gb pata hard drive and generic dvd rw drive. Imagine these wont add much.
I am planning on using the onbard graphics initially, altthough the flexibility of being able to add a decent graphics card later down the line is appealing. By my calculations any of the following power supplies should be sufficient, but the whole reason I'm here is I don't entirely trust my calculations. If you know of a better power supply within reason of cost, please tell! Thanks Ahead of time!
XCLIO STABLEPOWER 500W
Would like to avoid leaving this price range, but would.
XCLIO STABLEPOWER 460W
COOLMAX CR-450B 450W
Sunbeam PSU-BKS580-US 580W
May be sufficient, but only has one rail. Not sure what advantage multiple rails hold.
Ultra LS500 Lifetime Series 500W
Thoughts please! If any of these power supplies are sufficent, what would be best performance/value wise?
ASUS P5Q-VM LGA 775
