Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > Static sound from speakers on GA-MA69G-S3H
Forum Motherboards & Memory : Gigabyte - Static sound from speakers on GA-MA69G-S3H
I recently installed more RAM and another HD in my box that has a Gigabyte GA-MA69G-S3H (w/Vista 64bit installed). I noticed that there is static coming from my speakers now. Therefore any music playing comes out as static. I also noticed some static in the screen when my box is shutting down. Has anyone run into this before? Is this it a possible loose connection or something?
Sponsored Links
Have you plugged anything new into the AC circuit that serves the room that the PC is located in? Could be line noise leaking through, especially if there's a motor involved...
Reply to bilbat
No, but after checking what I installed. I found that once I removed the 2GB of RAM I added the speakers were static free. It doesn't make any sense to me, but that works so far. Still I have to figure out why adding the extra RAM screwed it up.
Thank you for your suggestion!
Reply to mawaru
The problem is not in the new Crucial 2GB (2x1GB) RAM I installed. I installed it and removing my older RAM and found no problems. Static sound was coming from the speakers only when 4GB of RAM was installed. Any ideas?
Reply to mawaru
Jeeez! That's REALLY strange... You wanna think adding RAM cures problems, not causes them! Nothing at all comes to mind, but I'll let it mull for a while - sometimes my subconscious comes up with surprise "AhHa's", usually at the oddest times...
Reply to bilbat
I have the same problem. Adding ram interferes with my sound and my video drivers. Did you ever find a solution?
Reply to netsprinter
No, I have not found a solution yet.
Reply to mawaru
What's running in the background? I run all four OSs: Vista 32 & 64, Xp 32 & 64, and I've noticed oddball problems like this when some (apparently) interrupt-hungry programs run unseen in Vista64; main offenders I've found on my system are: Nero, Corel (piece that came with PaintShop seems to want to monitor I/O continuously), and HWMonitorPro...
Reply to bilbat
There are 765 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
