Help choosing parts for gaming pc
I am looking to build my first computer for about $1200 including the monitor. I am wondering if this is a balanced build and if it is worth the money. Here is what I am going to get:
RAIDMAX SMILODON ATX-612WBP Black 1.0mm SECC Steel ATX Mid Tower Foldout MB Computer Case With 500W Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16811156062
(Is the 500W power supply enough?)
ASUS P5Q Deluxe LGA 775 Intel P45 Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131297
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
(I plan on overclocking to at least 3.0GHz)
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
HIS Hightech H487F512P Radeon HD 4870 512MB 256-bit GDDR5 PCI Express 2.0 x16
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161236
SAMSUNG DVD Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151173
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
(Are coolers necessary?)
SAMSUNG ToC T220HD Rose Black 22" 5ms HDMI Widescreen HDTV Monitor
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001278
(Is it worth paying more for HDMI over VGA?)
I am not sure if everything will be compatible.
3 answers Last reply
More about help choosing parts gaming
  1. the power supply that comes with that case is most likely Raidmax also, so its crappy. and its really not smart to go cheap on the 1 piece that can short-circuit and take everything out in ur system with it. try to get the cheaper version of the smilodon that has no PSU and get a PSU from a good company like Antec, Corsair, PC Power & Cooling, OCZ, or Seasonic. i'd recommend this one if u dont mind rebates:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817703005
    it'll last u for many years and u can most likely use it for ur next build.
    *edit* also, try to get the xigmatek retention bracket with that CPU cooler
    *edit 2* did u intentionally go with an LCD with a built in tv tuner? if not, then u can get one from Acer that's cheaper, brighter, and full HD (1080p-capable) but no tv tuner http://www.newegg.com/Product/Product.aspx?Item=N82E16824009152
    or a Samsung @ same price after rebate, full HD (but again, no tv tuner) http://www.newegg.com/Product/Product.aspx?Item=N82E16824001295
  2. Good build, but again watch out for that PSU.
    as diesel said, you can get a cheaper monitor with a better resolution if you go for one without a tv tuner, and you can always get a TV card for little money these days.
  3. Thank you for your help.
    I changed the power supply and got the retention bracket.
    PC Power & Cooling S61EPS 610W Continuous @ 40°C
    XIGMATEK ACK-I7753 Retention Bracket
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835233020
    I still haven't decided on the monitor though. I want one with built in speakers and 1080p.
    What's the difference between HDMI and the other inputs like VGA and DVI?
Components Product
