Alright, I'm wondering if anyone of you guys can help me. I haven't been here in the forums for quite some time now. I got 2 responses back then on how to fix my problem and it didn't work too well so i just gave up on it. It's been a few months and I'm experiencing the problem quite often once again.
- Anyways here's my specs, and then I'll describe the problem.
DFI X48 TR2
Intel Core 2 Quad Q9450 w/Arctic Freezer Pro 7
2x2GB Mushkin DDR2 EM-PC2 800mhz
500gb Seagate Barracuda 32mb cache
Gigabyte HD 3870 512mb GDDR3
LG 20x DVDR SATA and LG 6x BDR SATA
Sabrent Card Reader w/SDHC support
600w OCZ StealthXStream PSU
Windows Vista Home Premium 32bit
Alright now here are my problems.
1. When I shutdown my PC, if I turn it back on w/in 5 or so minutes, it doesn't power on and I have to clear my CMOS. (If I power off, then leave it for 20 or so minutes and then power it back on, it boots up properly w/out the need of clearing CMOS)
2. (Similar problem to #1) Whenever I Reboot my PC, it shuts/dies down and I have to clear my CMOS. The PC has only rebooted 4 or 5 times successfully since I've got it.
3. If I change anything in BIOS after a working boot-up(explained in #1), if I save and exit, it saves, exits and then doesn't reboot (like in #2). Is there a way to save BIOS and go straight to Vista?
I just don't know what to do... 'cause I hate it that every time I update Windows or Catalyst Control Center, etc., I can't properly reboot back to Vista. Also I almost always have it on Sleep (because of the problems). I just want a proper PC like my old HP. And plus, I can't/haven't even bothered overclocking becasue of the problems.
Note: I kind of knew what the two guys back then were saying. In the BIOS, there is a STR or S2R (Suspend to Ram). The default BIOS does have that on, which is the one I'm always using 'cause I can never mess around with the it.
Also, in BIOS, I have Boot Up FSB or something similar set to Auto, should I lower and try that?
I'd appreciate it if anyone could help me out?
DFI X48 TR2
