Tom's Hardware > Forum > Homebuilt Systems > New System Build > First build/need advice
Forum Homebuilt Systems : New System Build - First build/need advice
Sponsored Links
unless you do a lot of mutlitasking, a quad core is not required for a conservative gaming rig, as far as games performance goes you will get better bang for the buck with a dual core.
Other than that, everything looks compatible and pretty well balanced (although with ram prices the way they are, 4g might make sense for extra speed in vista by taking advantage of precaching with that powerful processor)
Reply to masterclam
- 0 +
Changes approved.
8GB won't be necessary but 4GB now would be a good idea.
The P5Q Pro is a Crossfire MB - not SLI but if you're just using a single 9800GT for now that isn't a problem.
Reply to WR2
Looks fine to me.
Reply to Cranky1970
I would definitely go with 4GB off the bat, especially with Vista 64-bit. 64-bit Vista actually uses a little more RAM and is a lot happier with 4GB. With the prices of RAM right now, there is no reason not to go with 4GB.
Here's a good read on the subject:
http://www.corsairmemory.com/_appn [...] alysis.pdf
I originally built my rig about 1 1/2 years ago with 2GB and 32-bit Vista. I recently upgraded to 4GB and 64-bit Vista and couldn't be happier.
Reply to shortstuff_mt
- 0 +
isnt the ram too slow?? mobo supports 1200 but ram is only 800.
Reply to koontie
- 0 +
The RAM is just right.
Reply to WR2
- 0 +
Thanks for the help. I'll definitely be going with 4GB of RAM then. Changed some stuff up to save about $100, the Antec 300 had a combo deal with an Antec true power trio 650W for only $119. So I ended up buying that last night to start the build, I figured I can just custom fit a window on the 300. Also I decided to go with the Q6600 again since I figure it might be more future proof with the quad core and chose a smaller hard drive. Also can anyone reccomend a nice CPU fan, preferably with an LED(I like pretty lights, lol). Let me know what you guys think.
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard - Retail
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor Model BX80562Q6600 - Retail
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-2GBNQ - Retail
Western Digital Caviar SE WD1600AAJS 160GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
ASUS 20X DVD±R DVD Burner with LightScribe Black SATA Model DRW-2014L1T - Retail
Microsoft Windows Vista Home Premium SP1 64-bit English for System Builders 1pk DSP OEI DVD - OEM
Antec True Power Trio TP3-650 650W ATX12V SLI Certified CrossFire Ready Active PFC Power Supply with Three 12V
Antec Three Hundred Black ATX Mid Tower Computer Case - Retail
Message edited by krame on 09-20-2008 at 10:47:19 PM
Reply to krame
- 0 +
Well, here she is. The build went really smooth, no problems and surprisingly quick considering this was my first build ever. Not completely done, better CPU cooler, new card later on and some case mods.
http://i244.photobucket.com/albums/gg38/Krame86/IMGP3372.jpg
http://farm4.static.flickr.com/3250/2928845402_ee8a220652_o.jpg
http://farm4.static.flickr.com/3143/2928843708_6b1be4ca9d_o.jpg
http://farm4.static.flickr.com/3203/2927984953_fea232486b_o.jpg
http://farm4.static.flickr.com/3154/2927986451_9b2f7570f9_o.jpg
http://farm4.static.flickr.com/3283/2927987481_8b7a5b9c1c_o.jpg
Cooler Master 690
Antec Earthwatts 500W
Asus P5Q Pro
Intel E7200
EVGA 9800GT
Western Digital 160GB 7200RPM
Lite-On DVD burner
Antec 80mm tricools(x2)
Thermaltake 120mm front intake
Windows Vista Ultimate x64
Message edited by krame on 10-10-2008 at 08:32:45 AM
Reply to krame
There are 1145 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
