Enter CCC. Make sure you are on the Advanced view Select your screen then under "Attributes" select "Enable GPU scaling" and place a check mark on 'Maintain aspect ratio"
Should be like this, remember to apply it
Message edited by nukemaster on 10-13-2008 at 10:13:55 PM
The only other thing i could think of would be to add some resolutions that match the height of the screen to the games.
800 x 600 = 960 x 600 (still 16:10) 640 x 480 = 768 x 480 (Still 16:10)
There is a link on adding more custom resolutions to CCC, with some luck you can run windowed games with your screen at low rez to avoid the small window effect.
nuke master i have 960*600 but for some reason (if u fix this ill love u) ALL the text is squishy and like idk its kinda like my monitor cant handle it or something, it really grinds my gears
all the text is all screwed up and distorted or something if u no what i mean
if u cud help me fix that (idk if there is a fix) thatd be great
Nice, I've been looking for some of these suggestions for quite some time. Thanks for the contributions you posted in this thread all... especially nukemaster.
