I am looking at getting a case that does not have hard drive cooling. Meaning a case with no fan in front of the hard drive cage.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811108068
If I bought something like this would it be sufficient to cool a 500GB 7200RPM Hard Drive?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835200032
Do you only have to cool the top of the hard drive or is cooling the bottom equally as important?
Or can you be just fine with no cooling at all?
I would like to have some type of cooling to increase life expectancy
