Sign-in / Sign-up
Solved
Ocz Platinum PC3-10666 ram issues running at 1066mhz instead of 1333mh
  • Memory
  • Overclocking
December 23, 2009 10:09:03 PM
Hi I was wondering, since I bought my pc in parts, put it all toghether, my computer only runs at 1066mhz instead of 1333mhz, im running the new intel core i5 750 on a Asus P55 LE Motherboard, can someone please tell me how to set my timings or what to set to so I can fully use my 1333mhz speed, appreciate the help, Merry Christmas!
More about : ocz platinum pc3 10666 ram issues running 1066mhz 1333mh
a b K Overclocking
January 3, 2010 2:34:57 AM
What is the setting of your BCLK(base clock)? Is it at the native value, 133?
Manually set your memory multiplier/ratio to 10x if you are at 133 BCLK.
m
l
January 3, 2010 3:34:14 PM
actually ty, but i found out the problem, in my ram timings my "TFRC" was set too low, therefore causing my ram to run at 1066, i changed my TFRC from 72 to 82 and now ram runs at full speed :)
m
l
Best solution
a b K Overclocking
January 3, 2010 9:36:07 PM
Always set the timing of DDR3 MANUALLY according to the datasheet of your RAM which I assumed you did, but you didn't .......
a b K Overclocking
a b } Memory
January 25, 2010 12:21:07 AM
Best answer selected by r_manic.
m
l
