hello, i just bought a 4850. after installing it, i turn on the pc and it gives me "connect power cable to the graphics cards".
i looked at the gpu and i found out that the power input is a 6 pin arranged in a rectangle formation ... i checked the manual, it says to plug the 2x3pin or 2x4pin ... and the problem is that i cant find any of those pins in my power supply.
can anyone help?
can anyone help?
