Hi there,
I have recently built a pc system, for the first time, to game on. I partly wanted the P5Q Deluxe b/c it had a digital optical out from the onboard sound card that i could plug straight into my Marantz A/V amp (supports both DTS&DD). I have used this A/V setup with a 360 for many years and thought the same would be got from a PC.
I noticed that I wasn't getting any surround signals when playing PC games so questioned if there were the correct encoders/card ability for this, then i realised i was getting surround from dvds.
Now after doing a bit of research it appears that no games actually put out true 5.1 signals (on either PC or console) but only use DDL or DTSI to take a stereo signal and turn it into untrue 5.1. I would really appreiciate any info on this as i find it hard to believe that some of the 360 games Ive played in the past were not in true 5.1. How can DTSI/DDL proactively mix sounds to the correct directions from the players perspective(behind), if there is only a stereo signal?
And if games only ever put out stereo signals how can some claim to have surround?
Any info with regards to this will help me out no end, thanks.
