anyone have any thoughts or last minute modifications that i need to make? Anything wrong with a selection i made?
MOST IMPORTANTLY: is everything 100% compatible?
Any advice is welcomed.
This will be my first Homebuilt.
Thanks
*list is now complete*
Message edited by tritan on 09-21-2008 at 07:52:36 PM
MOBO -I would go X48 Chipset. The two below are X48...
-Asus P5E Deluxe or for a bit more money Asus Rampage Formula.
I have both MOBO's and love them They would work with your picks. The Rampage (c/w the P5E Deluxe) basically gives you two (c/w one) LAN ports, more MOBO fan ports, and a small LCD screen read out gadget. The two MOBO's are otherwise basically the same.
Could save money going with a P45 chipset MOBO. The X48 would give you some speed advantage if you add a second 4870 GPU. (both PCi-E SLOTS go at x 16 c/w one x 16 and one x8).
Other suggestions...
HD Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive
CPU COOLER[b/]
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
-get the retention bracket with it
XIGMATEK ACK-I7751 Retention Bracket
[b]CASE -Can you afford the Antec 1200? I hear it is a upgraded 900.
GPU -great choice on GPU. If you plan on getting a second 4870 (no clue on yor plans or budget) why not just get 4870x2 GPU?
The rest of the choices are very solid (I have a lot of them on the build I just did IoI)
CPU COOLER[b/]
sure go back to the Corsair HX 1000
Its a much better PSU, better efficiency etc.
Ull save that discount on efficiency alone
Also do u want a full tower??
The 1200 is fairly tall as it is sitting here next to my bed. I had the Antec 900 and it was very good. The 1200 is just a tad bit taller....
yeah, honestly i dont want to have to deal with cramming stuff into the 900, mostly because i have never built a system before and dont want to snap my mobo in half lol.
I have both the Antec TPQ-850 850W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS BRONZE
and the...
CORSAIR CMPSU-1000HX 1000W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply
Both PSu's are great. I got a great deal on the Antec via newegg (thus I think my assessment is a bit biased) but kinda like it a bit better than the Corsair IoI. From all I hear, however, the Corsair is a BETTER unit (better quality and more stable). The Antec 1000w you picked out is NOT modular. This would be a big turn off for me.
If you are staying with one 4870 GPU, the 850w would be plenty. I went with the 850w Antec for my rugrats build with a 4870 GPU. I went with the 1000w Corsair for my build which has the 4870x2 GPU. Since the price difference on newegg is about $40.00 between the two....I would go with the Corsair.
If you have the room, larger cases make the build easier with the extra room. It also enables nicer air flow for good cooling.
I went with the Cosmos S for my rugrats build. It is a very nice case. I went high end with my build....Lian Li A7110. Lian Li is $$$. I have heard comments on prior reviews that with Lian Li, you gotta see the case in person to appreciate them. It certainly is the case in my experience
Well if u plan on CFing leave the X48
P45 boards go to x8 x8 which bottleneck the gpus
(also look at comment about PSU)
nah, not going to crossfire, ive decided just to stick to single gpu solution
friends recommend the maximus II because of the stability & user friendly OCing and such.
also thanks for the advice on the PSU, but its about a $100 difference because of the deal on the antec. I'm really going to have to stick with the antec PSU for now but if it gives any problems at all, I can get a corsair in the future when the money is there.
So basically now the only changes to the build first mentioned is HD, MOBO, CASE, and PSU
Anyone detect anything horribly wrong?
Message edited by tritan on 09-20-2008 at 10:49:34 PM
U probably dont need the Maximus....its a lot of money for bling (i got it cause i love parents (they owed me a lot of money so they paid for the build)
The P5Q-E will OC just as far and is much nicer on the pocket. Also u can get a combo with the HX 1000 which takes $30 off.
If u are not CFing, then dont get the 1000. The 850 variant is much better b/c the 1000 is just an overwattaged 850 = less stability. A good 750 PSU will hold that build easily
are there any real risks/dangers associated with using a 1000w PSU with this build? because as much as i think i wont, i might actually need to CF in the future....
A 850 could also take CF (a good one at least). They always overshoot on calculators for PSUs.
Any dangers/risks....no not at all. If u have the money get a 1000 its just that specific Quattro is the same 850 that they just made to do 1000 watts and when loaded that high it starts to lessen on ripple and regulation.
But u should seriously check out the P5Q-E if it has the features u need with the HX 1000 combo. but again its ur build
Yeah i've looked at the p5q-e, its just that i want to spend a bit more on the mobo to get one that is slightly more futureproof, i dunno...
on one hand, the rampage allows for better CFing.. which i may need to do year(s) from now (i cant buy a new mobo / rig every year...)
on the other.. the maximus is really user friendly and a breeze to OC, but has 8x CFing..
unless someone has a better (read: future proof) choice
edit: my friend is strongly suggesting the maximus II, saying that a single GPU solution will be fine as long as PCI 2 is still used, no CFing will be really needed
Message edited by tritan on 09-21-2008 at 08:48:26 PM
the P5Q-E IS THE Maximus....it isnt any more future proof exact same features. same overclocking its all bling....and i kno im a hypocrite that just bought one i kno....rofl
But im telling you...yes the Rampage is for CFing and IF u intend on doing it get that, but in terms of single gpu the P5Q and Maximus is the exact same thing.
of course not nothing wrong with bling. I got it cause 1) It was all money my parents owed me and 2) If i H2O cool the Maximus has a special block so i dont need to replace all the stinking heatpipes, SB cooler, mosfet coolers etc. It just goes right where the NB is
------------------------------Antec 1200|Antec Signature 850w|Asus Maximus II Formula|Q9650|4GB Dominator 1066|EVGA 9800GX2
Reply to Silverion77
