New Build Help
Forum Homebuilt Systems : New System Build - New Build Help
I havent built a computer in 7 years. Looking to build something that will last me a few more years. I do not know a whole lot about most of these. I do want to beable to go SLI but I will purchase the second graphic card in another month. Please let me know what you think and if you have any recomendations. My fund is around $1700 right now.
1 Intel Core 2 Quad Q9550 2.83GHz LGA 775 95W Quad-Core Processor
Item #:N82E16819115041
1 GIGABYTE GA-EP45T-EXTREME ATX Intel Motherboard
Item #:N82E16813128350
1 OCZ Gold 8GB (4 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Quad kit Desktop Memory
Item #:N82E16820227290
1 ABS Tagan ITZ Series ITZ1100 1100W Power Supply
Item #:N82E16817814002
1 Western Digital Caviar Black 1TB 3.5" SATA 3.0Gb/s Hard Drive
Item #:N82E16822136284
1 Western Digital VelociRaptor 150GB 3.5" SATA 3.0Gb/s Hard Drive (bare drive)
Item #:N82E16822136296
1 VisionTek Radeon HD 4870 900244 Video Card
Item #:N82E16814129113
1 LG 20X DVD±R DVD Burner with LightScribe Black SATA Model GH20LS15
Item #:N82E16827136151
XCLIO Amazing Fan - 12cm Red, Blue, Green & Random LED Case Fan
Item #: N82E16835234001
XCLIO WTBK ADVANCED Fully Black Finish Computer Case
Item #: N82E16811103019
Sponsored Links
Current Intel chipsets can't do SLI. Only Crossfire. I think you meant to say CF.
Plan to overclock the cpu?
Reply to auscanzukus
Drop that mobo...the T has DDR3 which 1) is expensive 2) unneeded and 3) wont work with DDR2....
Get a good Asus board like the P5Q-E or Deluxe
If u plan to CF then go with an X48 so theres no bottlenecking (Rampage Formula)
Also do u need a velociraptor?? I mean it will help load speeds but something like the WD 640 AAKS is plenty fast and has a great price per GB
Edit**: Also switch out that PSU for the Corsair HX 1000. Its still overkill, cheaper and is better quality (CWT good vs. Topower okay)
Message edited by Silverion77 on 09-20-2008 at 04:27:14 PM
------------------------------ Antec 1200|Antec Signature 850w|Asus Maximus II Formula|Q9650|4GB Dominator 1066|EVGA 9800GX2
Reply to Silverion77
Thanks for the input. Dont really need the velociraptor, just wanted to make something that will last a little bit. The WD 640 AAKS, is that WD 6400 AAKS?
Reply to mbsweaty
??? no its the Western Digital 640GB AAKS its $85 on newegg
also look at other things i suggested
Tom's Hardware > Forum > Homebuilt Systems > New System Build > New Build Help
There are 1265 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
