Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Need advice on CPU and motherboard from the experts
Forum Homebuilt Systems : General Homebuilt - Need advice on CPU and motherboard from the experts
Thanks in advance for helping me with my questions.
I am looking to put together a new computer. It will be used for a mix of work and play. I would like to be able to play games (mostly mmo's) while also being able to encode video. I have a 24" monitor but would on occasion like to hook it up to a 46" LCD for streaming video (not sure how possible that is).
My question is... I am thinking of a quad core... would you guys rec a Q6600 or a Q9550? I will be overclocking although I am not the type to push a component to its maximum limit.
Also... I am thinking of getting a 4870... maybe a 4870x2. What motherboard would you recommend? I most likely wont crossfire but would like to get a motherboard that works well. I am not as concerned about saving a few bucks here or there as much as I am about overall quality and function.
Thanks again
Sponsored Links
P5Q -E... yes it's technically a CF board but really it's just a solid overclocker with a lot of good features at a good price.
Q9550 because the extra speed really will make a difference in games, but more games in the future will use multithreading... and your video encoding software will like it too.
I think a 4870 would be fine. Given your monitor you might get more time with an X2 however, before obsolescence.
A Corsair 650TX PSU would be a good match with those parts.
Reply to Proximon
- 0 +
What are you other parts in this build? Namely the case and PSU? These 2 parts are pretty crucial to a nice and cool and quiet build. Do you already have the other parts to finish off the build?
------------------------------ PSU Tiers
GPU Power
8800gtx w/e6600 OC'd will run on Antec 380w w/27A on 12v rail, PSU!!
Reply to lunyone
I havent purchased any components yet. I was thinking of the Antec 900 as it seems to be well liked. The P182 by antec also appeals to me as Im not much for the bright lights.
I was thinking about the corsair power supplies.. 650 versus 750. I just need to do a little more research to make sure I am not shorting myself on power if i need it. I would rather just get a 4870x2 than crossfire. Im also planning for Vista 64 and starting with 4gb ram.
I plan to do most of my spending through Newegg... i have had good experiences in the past and am more worried about reliability than absolute price savings.
Reply to wmchad99
Well, now adays you can use an HDMI cable on a 4870 to output to an LCD or Plasma. Just make sure you get a card that has the HDMI adapter. If you can afford a 4870X2 then I say go for it, otherwise get a 4870 1GB.
------------------------------ Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
- 0 +
Asus and Gigabyte seem to be pretty solid on Intel mobo's. Gigabyte might be just a bit better (very slim difference). Depending on what your budget is and what your looking for in a mobo (options). I've have a comparison of several p45 mobo's here. Any of these will be just fine for what you want. The budget can sometimes dictate what you can afford and thus what will work for you.
As far as the PSU's, you are selecting very good PSU's. I'd go with the Corsair tx 650w as a good starting point. If you want to leave room for more upgrades later than the Corsair tx 750w would be a good one to have. Newegg doesn't always have the best prices on PSU's, so consider that.
Corsair 650tx at Buy.com. $93 - $20 MIR = $73!!
Newegg's Corsair 650tx. $110 - $20 MIR = $90.
Corsair 750tx at Buy.com. $104 - $20 MIR = $84!!! Only $11 more than the 650tx!!
Newegg's Corsair $130 - $20 MIR = $110.
GPU Power
Reply to lunyone
There are 1141 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
