I know I have to upgrade the power supply to about 500 watts to be safe. But the video card calls for an 8 pin power connector? Is that just a PCIe 6+2? or what? I'm confused!
Please help.
Also, any suggestions for a cheap psu would be great. I think I need a 20+4. THANKS!
I included the 600w and 650w since their price is so close to the 500w ones, that it might make sense to go with the higher watt ones if you may use it for a new build in the future.
Only price. If it was my system and i was buying a power supply for it, i would buy the Antec EA 650. The prices are close enough that the extra $$ aren't a big factor and i would use the power supply in the future when i upgraded my system or built a new one. You may have different priorities though. Here's a review of the EA650
http://www.jonnyguru.com/modules.p [...] y&reid=110 Here's a review of the OCZ 600 StealthStream
http://www.hardwaresecrets.com/article/451
