OCZ Fatal1ty Edition 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory (The Official Memory of the Championship Gaming Model OCZ2F10662GK
Item #:N82E16820227335
Return Policy: Memory (Modules, USB) Return Policy
-$15.00 Instant
$30.00 Mail-in Rebate
$85.99
$70.99
COOLER MASTER Real Power Pro RS-750-ACAA-A1 750W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply
COOLER MASTER Real Power Pro RS-750-ACAA-A1 750W Power Supply
Item #:N82E16817171024
Return Policy: Standard Return Policy
-$20.00 Instant
$169.99
$149.99
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler
Item #:N82E16835186134
-$5.00 Instant
$36.99
$31.99
COOLER MASTER cosmos S RC-1100-KKN1-GP Black Aluminum ATX Full Tower Computer Case
COOLER MASTER cosmos S RC-1100-KKN1-GP Black Computer Case
Item #:N82E16811119150
$259.99
Microsoft Windows Vista 32-Bit Ultimate for System Builders Single Pack DVD
Item #:N82E16832116213
Return Policy: Software Return Policy
-$20.00 Instant
$189.99
$169.99
Seagate Barracuda 7200.11 ST31000340AS 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
Seagate Barracuda 7200.11 1TB 3.5" SATA 3.0Gb/s Hard Drive
Item #:N82E16822148274
Return Policy: Limited 30-Day Return Policy
i would defiantly go with inlet like silverion77 said
I am not sure o this but im sure some 1 ill correct me if im wrong, if you are going to overclock then go for the faster ram. If not go with 800 as there will not be a major performance gain wit the faster RAM
I agree with the above posters about switching to intel and 4gb's of ram. Also, if you follow the ram advice, I'd say also get vista 64bit, so that it can actually use all 4gb's of ram.
Personally, I'd also prefer ddr2 800 ram over 1066 because you can overclock most cpu's pretty high with it at a 1:1 ratio.
Also for a lot less money I'd get this PSU instead:
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
Oh, don't bother getting the sound card. The Onboard HD audio is actually already better than what you picked(unless you get Xi-fi, which has Vista driver problems or HT Omega, problems free).
Message edited by johnyeah on 09-21-2008 at 11:27:40 PM
------------------------------"If you don't plan on listening, why ask?"
Reply to johnyeah
