Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > HELP! serious issues with my computer, any input apriciated
Forum Graphic & Displays : Graphics Cards - HELP! serious issues with my computer, any input apriciated
i play 3-d mmorpg games alot, and one day, i was playing one of my favorites, and all the sudden the screen froze, next things i know the screen went black, than started flashing CRAZY colors, and crazy patterns consisting of an assorted array of lines, and would switch crazy colors and line formations randomly, at first this only happend when i would try to play this game. i talked to dell support, and they said it was the game, i was thinking it was the graphics card. well i listened to him cause it only did this in that game, but then i tried a few others to see if it really was that game, well every other game i tried, it did the same thing. the dell support team is just incredibly idiotic, i kept getting switched from one team to another with out any answers, the hard ware department told me it was a software problem, the software department told me it was a hardware problem. and while this whole thing was going on, i kept saying it was a graphics card problem, well soon after i got no were with dall, and stoped calling. my computer started doing it randomly weather i was playing a game or watching a video. now i cant get on longer than 5 minutes without it freezing and giving me crazy colors. half the time when i try to rebot, i get the same crap at start up before anything comes onto the screen. i have to restart my computer like 4-5 times before it starts up correctly. i though it MIGHT have been my monitor, so i tried 3 others. same crap.so now what i wanna know is, is it my graphics card thats causing these issues, or could it be something else. also if it is a graphics card problem, what should i replace it with. ive done some research on cards, but idk what would be best for watching loads of videos and playing games like, asda story, comand and counquer 3 when it comes out and WoW, that wouldnt kill the money in my wallet. i have a dell insperon 530 with 2gb ram, a intel core 2 duo processor, and a 500gb hard drive, i think the current graphics card is a nvidia 8600 gt, not completely sure tho, your help and insight into this issue would be much apriciatetd, sorry for the grammer and spelling issues, im trying to type this before my computer goes hay wire again.
Sponsored Links
RMA the card to Dell. Escalate the call to management and onward as far as you must.
Reply to ghmage
they bsed me for a week until my warrenty ran out, now they want 150$ for a year extension on my warrenty, i talked to management and they were as inept as the staff, rather use that 150$ for a new graphics card rather than a warrenty extension, which will only get me a replacement on the crappy graphics card i already have, and thats IF they want to. they didnt seem to keen on the idea when i last talked to them, in fact one of the managers hung up on me -_- cause i was getting pissed from getting the "run-around" all i want to do now, is figure out what the problem is.
Message edited by mrgangster89 on 10-16-2008 at 07:07:15 AM
Reply to mrgangster89
- 1 +
hey !
i think your graphics is the problem. i got the same errors when a few years ago i had a riva tnt2 and the cooler stopped and the card begun to heat up to ~90-100C . check it by touching it. if it's hot (like "ouch" ) then that's the problem.
you said, that you aren't sure of your video card model. download gpu-z. gpu-z will tell you everything about your gpu : http://www.techpowerup.com/downloads/SysInfo/GPU-Z/ <- download it.
maybe, you can check your processor's temp. cpu-s can do crazy things too when are overheated. you can check the chipset's temperature too (the north bridge is the most important, the south bridge - if it's separately integrated - isn't so hot)
with 150$ i'd say get a new video card. dell computers as far as i know are quite well built, new cpu-s won't burn if you take care of them (not overclock all the time, sometimes clean the cooler from dust, ....) , mobos are the same ok, only hdd-s are sometimes faulty.
good luck !
Reply to t85us
- 0 +
did you check to make certain that the card is properly seated and connected,if so then replace it.also check your ram also,check all your connections,i had a hdd go south on me once finally found out that it was not connected firmly to one side of the ribbon cable,douh!!...:)
Reply to dokk2
i opened up my computer and when i was looking at the card, i took it out and put it back in to make sure it was connected properly i checked my ram, but i notice that the fan on the chip seemed stuck, its at 82 degrees celcius and the computers been off for 2 days, and i just turned it on its only been on for 5 minutes, i have an nvidia 8300 GS, i also dont know what OR how to overclock my computer, my computer, my gpu temp is currently 90 degrees celcius, which i dont THINK is good.!! OK ITS OVER HEATING !! its currently at 102 celcius. i opened up my cpu while its running and the fan on the card, isnt working. so now what, can i fic the fan or do i need to replace my card ?
Message edited by mrgangster89 on 10-17-2008 at 04:31:35 AM
There are 1275 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
