Ok, you feel that you need water cooling to overclock a Q9450 to 3.6 GHz? That can be easily covered by aircooling, hell a high end one could be overkill.
Do you plan to water cool those GPUs?
i want to install water cooling system mostly for the GPUs because they get HOT
For the three GPU,s you would most likely need a triple radiator and FC/fullcover
waterblocks as dpending on how close they are together a separate waterblock with
ram/mosfet heatsinks may not fit.
If you include the CPU probably a triple radiator and a dual radiator would be
best. Maybe a dual loop set up as well.
the problam is that i can not find a FC/fullcover water block for GTX 260 so i'll go with gpu water block and ram/mosfet heatsinks. you saying that triple radiator will be good for 3 GPU and CPU?
