Platin Couffin engine for 64bit System (AMD) fault
Last response: in Windows 7
September 7, 2011 10:17:37 AM
Platin Couffin engine for 64bit System (AMD) is faulty.
Problem found on many computers is due to a 'Windows 7 update issue' apparently
I have been told a factory reset is the only answer... Sugar!
a b $ Windows 7
September 7, 2011 10:29:25 AM
Patin Couffin engine is used for burning DVD's, so its likely that your DVD burning software is at faul and not windows 7 -
what software do you use ?
