Hey all , just installed windows 7 64 bit and latest CCC Build + drivers.When I try to overclock the 4770 I reach 840 mhz / 1000 mhz / 1.04 voltage.This is fully stable and is able to run for a prolonged time in Furmark Xtreme burning mode.Everything seems fine except when I was using windows XP i was able to get 930 mhz / 1000 mhz / 1.05 voltage.Anything above 840 mhz on windows 7 results in a crash asap.So what gives?Is windows 7 the problem or my card just got worse?Its a Asus 4770 , im using SmartDoctor to change the voltage.Temps are 38-40 on idle when clocked.The memory is not the problem I tested that - ran on 750 mhz / 1000 mhz for 10 mins in furmark.Im really confused how such a big difference can happen .Hope someone here can help me out.Thanks in advance.
