Tom's Hardware > Forum > Wireless Networking > Range & connectivity > Terrible speed with trendnet wirless n pci card
Forum Wireless Networking : Range & connectivity - Terrible speed with trendnet wirless n pci card
I recently purchased a Trendnet TEW-641pc wirless-n card for my new vista desktop PC. We use AT&T's 2wire 2701HG-B modem/wireless router. My card always shows that it has excellent signal strength 98-100%, but I have dial-up speeds of 50-100 kbps. I tested the computer that is connected via ethernet cable and it was 1290 kbps. A few older computers with Linksys WUSB54GC USB wireless-g adapters are working at about 1100 kbps to 1200 kbps.
In addition, there is an unproteccted wireless network I am able to connect too with an 80-90% signal strength, but it also is slow on my computer in comparison to my co-workers.
So I am assuming the problem lies with my wireless card. I am not sure what I can do to get my internet connection up to a decent speed or if I have to buy a different card.
Sponsored Links
reviewers on Amazon who purchased noted the same experience that you did. I would try a different card.
Reply to festerovic
If it is possible, try turning off the "N" signal in the adapter properties window and run it as B/G.
Reply to lyleb
Doesn't look like turning the N signal off is n option. Guess I will return it.
Reply to sig1043
if you have a b/g router, why get N anyways? G is fast enough for 90% of people (the bandwidth for 802.11g exceeds most folks ISP speeds)
Reply to festerovic
Trendnet was crap for me. Terrible USB N adapter. PCI Trendnet is terrible as well.
Go to keenansystems.com, and look at ENGENIUS--200-600mW!! of power and not costly. G is very fast and effective at that power level. Do N if you really think you need it. With Engenius,you will detect tons of access points nearby that you didn't even know were there.
Reply to botnot
I bought the Trendnet wireless N card because the wireless G card I originally went to the store to buy was not in stock. I have since returned the card and picked up a Linksys wireless G card and it is working just fine now.
Reply to sig1043
botnot, that was nerd porn for me. Seriously, I was drooling.
sig - glad to hear it's resolved.
Reply to festerovic
There are 908 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 demondrumer won the Freshman badge
  • 01:00 tehue won the Freshman badge
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
