Tom's Hardware > Forum > Graphic & Displays > ATI > HIS HD3850 IceQ3 Turbo (AGP) PROBLEM
Forum Graphic & Displays : ATI - HIS HD3850 IceQ3 Turbo (AGP) PROBLEM
Hello,
I have extremely irritating problem on this card: it crashes in every game I play and messed up textures appear! Card is not overclocked (720/1820). This seems like a memory problem, so I tried lower its speed. And guess what! NOTHING! Same crashes occur! It doesn't matter whether mem is set to 2000MHz or 1500MHz. In ATI Tool artifact scan utility card can work well for hours, but neither 3DM06 nor games run properly. I've tried all AGP hotfix drivers, then flashed card so that I would be able to use official ones, but nothing helps. Also set AGP speed to 66MHz and and tried out other possible moves. I have never experienced anything similar with Radeon 9800PRO, 9800XT, GF6800GT, 6800Ultra, 7800GS, 7950GT.
My PC:
ASUS P4C800 Deluxe board (875);
P4 EE HT @ 4.0 GHz CPU;
2GB Kingston HyperX 500MHz CL2 memory;
2 x 1.5TB HDD at RAID;
HIS HD3850 AGP IceQ3.
500W PSU 2.0 with direct 8 pin PCI-E 2.0 cord.
Other overclockers push this card to 2ghz on mem stable, so I'm starting to think it has a FAULTY MEMORY. Unfortunately I'm not able to return it back to seller because I bought card from Hong Kong and sending it back and receiving again will cost me ~110$, which I cannot afford.
Has anybody experienced similar memory problem? Any help will be very appreciated. Thank You.
Sponsored Links
I have the same card, except for it's the PCI-e version. It's possible that it's overheating, since the fan stays at a low speed, no matter the load on the card. You can try to increase the fan speed using RivaTuner or another fan-controlling program.
------------------------------ AMD Phenom II 940 | DFI LanParty DK 790GX-M2RS | 4GB Corsair XMS2 DHX DDR2 800 | EVGA GTX 260 Core 216 SSC Edition | WD 500GB & 1TB | Sound Blaster X-Fi XtremeGamer | Antec NeoPower Blue 650 | Samsung 941BW | Windows Vista x64
Reply to bdcrlsn
Have you tried setting the fan speed higher? Might be a temp problem.
Reply to stridervm
Unfortunately it's not an overheating problem ;/. I've been keeping fan fixed at 90% since I bought it. bdcrlsn, what is your max memory overclock?
Reply to lemon_19
My memory is running at a mild overclock of 925mhz (1850mhz), my core is at 775mhz, and I have the fan set at 50%.
Message edited by bdcrlsn on 10-19-2008 at 06:38:25 PM
Reply to bdcrlsn
Haven't you had stability problems with it? I mean texture mess up or signal loss?
Reply to lemon_19
hit windows key+r, type dxdiag see if it passes, if not the card may be toast. I had this problem with one of my old ATI cards, but ATI gave me a modified driver pack that apparently fixes the card, you should message them.
Reply to xNEM3S1Sx
There are 471 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
