Feel the Love & Check Our Lists Twice
Does anyone recommend a great panel?
ummm... What?
http://www.newegg.com/Store/SubCat [...] ler-Panels
^OP should have made what you're talking about. Just adding "fan" to the title would have made all the difference.
I use this one:http://www.newegg.com/Product/Prod [...] 6835118217and works well.
Then again, I usually add my own pots to control the fan speeds.
I have the ZALMAN MFC1 Plus-B, got it because the styling is EXACTLY the same as my black Lian Li case
You are about to answer a thread that has been inactive for more than 6 months.If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread.
