Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Mobo only powers up without the 4pin cpu power plugged in
Forum Motherboards & Memory : General Motherboard - Mobo only powers up without the 4pin cpu power plugged in
It's a Foxconn microATX mobo A7GM-S.
When everything is plugged it, no power. When I unplugged the 4 pin cpu connector, the mobo boots up. Fans come on and everything. But nothing on the screen. I changed the power supply to 650 watts from 500.
Any idea what is wrong? bad motherboard??? THANKS
Q-Pack2
A7GM-S
Athlon 64 X2 6000
4GB G SKill Ram
640GB HD
Blu-Ray Drive
Sponsored Links
It's always a bad sign when someone mentions a PSU without giving a brand or model.
With the 4-pin plugged in, will the board briefly power up when you unplug the PSU, leave it for a minute, then plug it back in?
Did you install the motherboard standoffs only in those places that correspond to screw holes in the motherboard?
Have you tried with just one stick of RAM installed? What are the specifics of your RAM?
Have you inspected the CPU for bent pins, and foreign material?
------------------------------ My Guide to choosing parts
A big list of recommended parts
Troubleshooting Guide w/links
Reply to Proximon
The PSU is Antec Neopower 650. The original PSU that came with the case is the stock PSU that comes with the Q-Pack2 case.
With the 4-pin plugged in, the board comes up for 2-3 seconds and then fades out. When I switch off and on again on the PSU, nothing happens. If I unplugged the 4-pin, then power on, everything comes on.
Yes, only screws in the correspond holes on the board.
I tried with two, one stick and no sticks.
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
CPU area and heat sink all clean.
Here's a brief history:
First day: got all the parts and installed in new case. Everything went well. Vista boots up. I was using the blu-ray player. Everything was running fine.
Second day: I decided to use the temp gauge thing that came with the case. It sends the temp of the HD n CPU to the front panel LCD.
So I plugged the power for LCD into the PSU. I taped the ends of the sensor to the HD surface. I taped the sensor to the heat sink of the CPU. Thats when it started not booting up right.
I thought it was the PSU, so I went and got the Antec Neopower 650. But got the same result with the new PSU.
I think I need to get a new board. I was look at RMA for Foxconn, it looks impossible. Newegg is not doing RMA for the board.
Any ideas from the above? THANKS!
Reply to nhkteainc
Have you tried re-seating everything??
I tend to look at what you have done... You went inside the case, tinkered, and poof it stopped working. There is a good chance that a cable or card was bumped. If I were you, I would unplug EVERYTHING, pull the motherboard out, and put it back together as you originally had it (without the temp gauge), put NEW thermal compound on the CPU heat sink, while the CPU is out examine the pins carefully.
In fact I would do this exactly, once everything has been unplugged/removed and the motherboard put back in, only plug in the bare minimum for the system to boot up.
Video card (make sure the PCI-E power is supplied to the card, if your card needs it).
1 stick of memory in SLOT 1
CPU 12v power
24pin Motherboard Power
CPU heat sink (Of course!)
If it refuses to make it to the POST screen, try a different Video Card (if you have one). You didn't mention that you were using a video card though, but If you are using a video card, remove it and use the on-board video.
If the system wont boot now try a different stick of memory in SLOT 1.
No boot yet? - Try the same stick in different slots, try them all. If it still wont boot try the other stick in the same manner (different slots). If you have any extra memory anywhere else, give it a try in the same way.
If the system still will not boot after all this, try a different CPU (if you have one). Try the CPU in a different motherboard (if you have one). You mentioned that a different power supply has the same effect, so I doubt that's the problem.
If you don't have extra parts to try I would say it's either the memory, motherboard, or CPU. Hard to say what it is.
If you manage to get it to boot during the process you will be able to find the problem pretty easily. Plug in one component at a time, hard drive try to boot again; if it refuses to boot the hard drive is the problem... etc etc so on and so forth.
Btw - Did you overclock anything at anytime? If so, read your motherboard manual and reset the BIOS. In fact just go ahead and reset the BIOS, it might fix your problem (stranger things have happened).
Message edited by ir_efrem on 01-19-2009 at 08:29:43 AM
------------------------------ Don't drink and park, accidents cause people.
Reply to ir_efrem
You should really try removing all memory sticks to verify mobo problem. Usually motherboard beeps when memory is not installed. Assuming no problem with board. Board with defects no longer beeps when memory is removed.
------------------------------ Intel Pentium 4 630 3.0Ghz Shuttle XPC SB81P(intel 915G)
Patriot Dual Channel 2GB DDR400: Raid0 640GB 2pc WD3200AAJS
Powercolor ATI Radeon HD3870 PCS 512MB DDR4
http://valid.x86-secret.com/cache/banner/414710.png
Reply to goonting
"G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory"
Again, please be more specific. Newegg has about 8 different kits matching this description:
http://www.newegg.com/Product/Prod [...] C2%206400)
Some of those might be problematic with your board.
Your system is not booting up. What is happening is that your power comes on with just the 24-pin connected, but the board never actually posts. When you actually connect the CPU power, the board tries to post, fails, and turns itself off.
Memory is always the first suspect in such cases. If you are using a highly volted kit, such as the 2.1V, that might not boot up without a BIOS adjustment first.
"Yes, only screws in the correspond holes on the board."
Not the screws, the standoffs is what I'm interested in. The ONLY place the back of the board should make contact is on the standoffs, and only in the proper places.
I would not have recommended the Neopower. Not a particularly good line from Antec. The Trio, Earthwatts, TPQ, or Signature lines are better. I doubt that's the issue though.
"I taped the sensor to the heat sink of the CPU. Thats when it started not booting up right."
That won't give you a meaningful temp reading anyway. I would certainly unplug the LCD and remove the sensors.
In fact, you should build minimally out of the case at this point, if nothing else has worked... on a cardboard box is good, but not on an anti-static bag as those can actually conduct.
ir_efrem gave you a bunch of good advice.
Reply to Proximon
Are you 100% sure that you are not trying to plug a 4 pin PCI-e power connector into it? I have done this before by accident, and it wouldnt power up.
Reply to merlinbadman
If your M/b is 775, check to make sure there is no dirt or fluff caught in the cpu pins.
Reply to sdg-400
There are 1055 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
