So I recently overclocked my CPU And Iv had a little bit of a problem. When i Turn off my PC and turn off the back power switch on my power supply, Then When i turn the power switch on the power supply back on as well as the Power to the Computer Then the PC turns on for a second and power cycles. And Then Turns on and posts and works normally. Now if i disable my overclock and go back to stock It does not to this power cycle on boot up. And it only happens when i turn off my power supply switch. IS this normal because the BIOS has to load the settings since there was no power or a problem? Motherboard is a Gigabyte EP45-UD3R
Your system is freezing up; probably a setting your board or memory can't handle. I would use the cmos jumper to reset the bios settings to default, and start over.
