Tom's Hardware > Forum > Homebuilt Systems > New System Build > Abit ip35 pro-New build-Postcode 6.d stuck pls help
Forum Homebuilt Systems : New System Build - Abit ip35 pro-New build-Postcode 6.d stuck pls help
Hello-Well after 3 hours of trying to figure it out. I gave in and wanted to ask the "pro's". Firstly, this is my first pc build. Im using the following:
abit ip35 pro
intel e8400
thermaltake 750w ps
8gb corsair xms2
vista 64 bit
Ok, I got everything put together today. I plugged my pc in and it does start no peeps. Though Im getting postcode error 6.d. Which stats in my user guide:
6.d
1. assign resources to all ISA PnP devices
2. Auto assign ports to onboard COM ports if the corresponding item in setup is set to "AUTO".
I have no clue what this means. Thus, after doing research on the net. Some suggested clearing my cmos. In which I did with no luck. I also disconnected the battery connected to my mobo for 1hr. This didn't help the problem.
Again, I have yet to install the BIOS because I cant get by the postcode 6d. Im really stuck here. I have no idea what the problem might be. Any vauled information would be very helpfull.
Thanks again in advance.
Sponsored Links
Clearing cmos requires unplugging the power cord. Did you?
Try each stick of ram in each slot, once the pc posts, go to bios, load default, bump ddr2 voltage a notch to no higher than 2.1v, install the other sticks.
Reply to auscanzukus
There are 1133 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
