I am using 2x4870x2 cards. Catalyst 8.10 and Vista 64bit.
My primary display is a NEC3090WQXi and second display is a Sony bravia XBR4.
On my primary display the colors are perfect. On my second display, the colors are completey messed up (at least 8500K temperature or more!!). Bascically, everything has a blueish tint. When I use a laptop to send the same images to the same TV, they are perfect color.
I did not adjust colors anywhere in catalyst or any other program. I checked every setting and it is default. Why are the colors way off on my second display?
When I unistalled catalyst drivers and reset, vista booted up with accurate colors on BOTH displays. Then when I resinstall catalyst, messed up colors on second display again.
