Ok,
So I figured instead of buying a new pc, I would build one. Now I'm having issues with my new build.
Here are the components that I'm using.
Intel Quad Core q9550
Stock CPU fan
Asus Rampage Formula
Corsair HX1000W PSU
8GB Corsair Dominator DDR2-1066
3 Samsung Spinpoint F1 750Gb HDD
Samsung DVDRW
I installed the components and booted the PC. I am able to get into the bios, but when I try installing Server 2K3 Enterprise, the PC automatically shuts down within 15-20 seconds of starting the install. But if I remain in the bios, the PC will stay on.
I think it might be the CPU temp and the bios states that its around 83 - 85 degrees C (185 degrees F). But I've been told the bios readings are not an accurate measure and I should use real temp. Since I can't install anything onto the PC, I have no way of checking if that is the problem.
I have double checked the stock CPU fan and its mounted correctly.
Any help would be greatly appreciated.
Stock CPU fan
Corsair HX1000W PSU
Samsung DVDRW
