Tom's Hardware > Forum > Graphic & Displays > ATI > 4850 overheating at 100% fanspeed !! help
Forum Graphic & Displays : ATI - 4850 overheating at 100% fanspeed !! help
I've got very high temps with my ASUS 4850 in the last 2-3 weeks...
Ive had my 4850 for 3 month. Everything waas ok for the first month, running cool temps with 40-60% fan speed , but latter it started to get 70C at 3d load and started to worry so i started to use the fan at 100%...
For the last 2-3 weeks, my temps no run 60C IDLE at 100% fan speed and got 96C at LOAD crashing my games...
Ireally need some support ...
Sponsored Links
How is the airflow on your case?
------------------------------ Anxiously awaiting the Hydra 100 and the Hydra Engine...
www.lucidlogix.com
Reply to emp
- 0 +
Also, check that the heatsink on the card is making good contact with the GPU. Those things can shift and not make full contact and you loose thermal conductivity on your chip.
------------------------------ Evga X58 3XSLI : i7 920 @ 4.2Ghz :GTX295+ x 2 :12GB XMS3 Dominator 8-8-8-21 1600 :XFi Fatal1ty:150GB WD VelociRaptor: 150GB Raptor: 4TB WD 32MB x4: Monsoon Vigor III: Lian Li P80 (black): BFG 1Kw PS: 37" Westinghouse 1080p 8ms :Vista64bit
Reply to warezme
I had a NZXT Tempest case which is supposed to has a good airflow. I have a 26c room temp. I also dont want to get an aftermarket cooler untill I find out the real problem of the issue...
Reply to realyeti
If it were a cpu I'de have a few idea's. Sadly, the only time this happened to me with a gpu, it was literally a gpu problem. Sometimes they just cook themselves to death. I mean, you can try re-seating the heat sink, but that normally isn't a problem with vid cards. Particularly if the card was working just fine, and then it starts heating up one day. RMA if possible.
------------------------------ "Since the dawn of time, man has dreamed of blotting out the Sun." - J. Montgomery Burns
Reply to hypocrisyforever
When I removed the fan & heatsinks off my brand new 4870's to install my waterblocks I couldn't believe how poor the oem compound was on the chip. First thing you should look at is replacing the thearmal compound with some good stuff.
70c is normal for the card under load but high 90's I would say is to high.
Reply to stoner133
80-90º is average
115º is threshhold
127º burnout
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
- 0 +
probably gpu has gone bad
i would RMA
Message edited by kamkal on 10-20-2008 at 06:58:37 PM
Reply to kamkal
^+1
Probably OK. You could also put new thermal compound, as someone suggested. That really helped my previous cards, so I do it every time I get a new card.
Reply to festerovic
I had a X1900XTX do exactly the same thing. I removed it and blew out the heatsink. I found a huge amount of lint/dust had collected at the end that air is drawn into. When I blew it out I got a strip of what looked like dirt color cotton batting out out it. This lint was limiting the amount of air being drawn in by the fan. After cleaning it, my temperatures returned to the same as they had been when the card was new.
The funny thing is this happened in a relatively short amount of time (3 months) considering I'm away for more than half the time.
So to make a long story longer, try cleaning the dust out of the heatsink and fan assembly.
------------------------------ Don't go away mad, just go away!
Reply to techgeek
- 0 +
well I would just rma it.
maybe they would give you the 4850 with aftermarket heatsink :D
Reply to alvine
- 0 +
realyeti I like a lot of others that have posted back to you about your problem fill you have some kind of heat problem.
techgeek has a very good suggestion could be just dust build up in the fin's of the gpu
the next thing I would try sense I don't know the mobo you are using,is check how close the northbridge heatsink is to the gpu,and sense most mfg never put a fan on the northbridge.and they say they don't need it. try running the pc for 30 minutes and then take side case off and touch the northbridge heatsink and see if it is real hot.maybe as simple as putting a $3.00 fan on the northbridge.hope this helps you out
------------------------------ ▐ ASUS RAMPAGE EXTREME II ▐ I7 920 ▐ 3 GIG CORSAIR 1600 ▐ BFG 280 GTX ▐ ANTEC 850 PSU ▐ ANTEC 900 CASE ▐ ACER 22" 2216WB LCD ▐ SAITEK ECLIPSE II ▐ LOGITECH G5 ▐
Reply to major53
- 0 +
Have you OCed your CPU?? if you have increased your PCI voltage or MHC the VGA will also overheat. I have a X1950 that at standard PCI voltage stays at 46-50 Idle. But if i put 0,10V in the PCI voltage it bumps to 65-70 with the same Fan speed.
Reply to xanxaz
I think XPERTVISION has a better cooling than ASUS one. My idle temp is around 44 C and under load reaches 55 C. Performance wise there is no issue......i think XPERTVSION is a good brand
Reply to saurabh_taurian
- 0 +
I got the exact same problem with my ASUS 4850. Worked perfectly for about 4 months, idling around low 50's with 50% fanspeed. Suddenly today, it started idling high 50's even with 60% fanspeed. Worst part is that when I was gaming, it hit 90's!! Since I didn't do it when I first bought it, I just applied MX compound. But, it didn't seem to help with the temps at all. After hearing your story, I think I'm going to stay away from ASUS cards from now on. I guess mobos are really their specialty.
Reply to zeroyb
evongugg wrote :
80-90º is average
115º is threshhold
127º burnout
Please do not reply here if you don't know anything about the subject. What you are telling is total non sense.
Mine is running at 30 idle and 40 load, 30% fan speed.
Reply to M-Ajesty
Techgeek has got a good point there. Either do that or RMA the card.
Reply to M-Ajesty
I'm using MSI HD4850..
Idle 40-50C
Load 60C
Reply to meodowla
- 0 +
Every card out there could be running as cool as the Fonz if the manufacturers would dump those stupid little centrifugal fans and the stupid cowling with the stupid blingy graphics, and put a damn rotary fan right on top of the damn chip! You think you can get all of the dust out from beneath that cowling by blowing compressed air in the fan? Ha!
Who the hell wants to pull and disassemble their card every time they want to clean it? :sarcastic:
GRRRRRRR! :fou:
Reply to Wrecks
take off the heatsink, make sure its not cloggged with dust, mine was, dropped my temps a lot after i cleaned it. reapply thermal paste, and try again. should help big time
Reply to dimaf1985
- 0 +
Hi there.
I'm new to this site, but so far I have enjoyed reading your feedback on this particular issue.
However, I would like to say just how suprised I am to see that I apperantly am the only one with a rather extreme example.
I bought my new computer approximately 4 months ago, with the graphics cards being 2*Radeon 4850 with Crossfire, and even back then the idling temperature of my GPU was around 80c, and would rise to high 90's, and sometimes cross over 100c.
These past few days I've been trying to figure out what might be the cause (do I not have sufficient cooling in my tower, etc?), invested a neat sum in extra coolers. However, none of this seems to help - infact the temperature of the gpu keeps rising.
Last night, when I was playing some Burnout Paradise, I got 3 error messages coming from the GPU's, saying that the GPU would reset, and asked me if I wanted to send the report to ATI.
I dont know too much about computers, but I've tried flashing my BIOS, downloading the latest drivers, updated everything which I could imagine having to do with the temperature. I've even tried enabling manuel control of the GPU fan speed, set it to 100% which makes too much noise, but still the heat keeps rising past 100c when I play something that requires the GPU to run fast.
Tonight, after work, I will try to blowout everything, and I really hope it works!
If it doesn't, should I try RMA'ing the cards, or what should be my next move?
Kind regards,
Flixe
Reply to Flixe
- 0 +
Fixed!
Blew out my cards with a air compressor, and they now run at 50-60c idling, and around 70c when working.
Thanks for the tip. :)
Reply to Flixe
I am so glad I found this thread! My card I applied was shutting the whole computer down with temps of 115c!!! I disassembled the card to find that the thermal paste on my VisionTek 4850 was all dry and cracked. Luckily I have an old tube of artic silver. After using compressed air and cleaning the gunk off the heatsink and gpu, and applied the thermal paste. At load I was shutting down...now I idle at 45C with full load at 57c with the fan at 100%. I don't mind the noise. Thanks
Reply to willkillagain
- 0 +
its the third and same problem , i have Asus 4850 5 month old , my temp is rising over 85C, earlier it used to be 60-65C. I am getting flickring on screen and my game crashes.
Reply to hg99
- 0 +
mmm....ive been having this same exact problem and Ive been looking into aftermarket coolers because Im worried about frying my card...guess I should just try reapplying the thermal paste first before I spend any money...
Reply to Ahslan
- 0 +
I will check into that too... but a lot of peoples are forgetting that crossfire setup take the temperatures 15C higher. For my part, I have put a 120 mm fan at one inch of the cards sending fresh air and my temps are never crossing 90C anymore.
I get to 85C in Crysis, but that's under the worst load... not to mention my cards are Asus TOP 4850 and are OC at 675 MHz. I am idling right now at 54C right now, but I was 5C lower 2 weeks ago (48C). I will check the thermal paste too.
Anyway, 4850 gpu are designed to work under really great temps.
"80-90º is average
115º is threshhold
127º burnout"
Even if these are the norm for the old cards, the gpu should be able to work in the same conditions.
M-Ajesty, Evongugg is right.
Reply to redgarl
- 0 +
so i just applied a thin layer of this cheap Dynex Thermal Paste I had sitting around (bought form Best Buy) and wanted to know how long should I be waiting before I put the card back in and fire up the card?
Reply to Ahslan
You're supposed to wait?!? Oops. I've always put the paste on and fired up.
Probably obvious, but reapplying new paste works well for a 4870 too. AS5 dropped temps 3-5* load is now 62*.
Reply to festerovic
- 0 +
damn...well i fired up the pc and started gaming and it seems like changing the thermal had absolutely no effect...guess imma have to get an aftermarket cooler...fail...
edit: actually, i think now the card even runs hotter...fml
Message edited by Ahslan on 07-23-2009 at 11:30:29 PM
Reply to Ahslan
ahslan, maybe you put too much paste on.
Reply to festerovic
- 0 +
you guys sure 127 is burnout, when my heatsink had a screw break it was running at 192 load for a week before i realised
Reply to rynoc
- 0 +
I actually made sure to put on a very thin layer...it was tough (my first time) but I felt I got most of the gpu very evenly (there were a couple of thin streaks from using the card)
Reply to Ahslan
There are 1120 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
