Archived from groups: comp.sys.palmtops (More info?)
Hi,
when i first got my palm, i charged the battery for only half hour
before turning it on. does this make a difference on later performance
of the battery. it seems to me the battery dies way too fast and i
think it may be due to the first short charge. please help, and let me
know if there is a way of fixing this (maybe reseting palm somehow).
also is it possible to format palm to have no data on it?
"the hotshot" <hotshot@inbox.lv> wrote in message
news:1108844844.907924.208190@c13g2000cwb.googlegroups.com...
> Hi,
The consensus is that T|E has a notoriously short battery life. One common
tip is to adjust the brightness down. There are battery packs available for
emergency charges, etc. And you can use the device while it's charging,
which helps in synching and some other tinkering.
On 19 Feb 2005 12:27:24 -0800, the hotshot
Hard reset. Press and hold the power button while pressing the reset
button.
the hotshot napsal(a):
> Hi,
Try in-cradle reset. Just stab him in the back while charging.
Hard reset. Push power + stab in the back. When you release the power
button, he asks if you want to clear all data. If yes, push UP.
Mark
thank you kindly for all your suggestions everybody.
the hotshot
> > Hi,
performance
me
somehow).
> Mark
> The last easy day was yesterday.
