I HAVE THE SAME PROBLEM U R ALL TALKING ABOUT..BUT NOW WHAT SHOULD WE DO IT CAN
sony_87
hI,I HAVE THE SAME PROBLEM WITH 128GB CHINA USB..BUT WHEN FORMAT WITH EXFAT IT IS GOOD I TRY TO STORE 25 GB AND IT WORKS!!BUT CAN'T USE IT ON XP WHAT SHOULD I DO TO USE IT ON XP? I GOT PROGRAM AND FORMAT IT FAT32 BUT WHEN I REMOVE FROM PC FILES DISAPEAR..SO HOW IT CAN BE USED ON XP PLEASE EVEN IT CAN STORE UP TO 16 GB IT IS BETTER THAN NOTHING
answers
Last reply
More aboutproblem talking about
Mimoso
You definitaly have a problem with your keyboard. Apparentely the Shift key seems to be stuck.
As for your other problem. The best thing you can do with fake USB sticks is to throw them away. Even if you can write 16 GB on it there's no guarantee that all data is actually on the flash memory.
