I have a Gateway 500x desktop (waits for laughter to die down), and the power supply sounds like a small airplane. I bought a new/cheap one from Newegg, but it doesnt fit. The supply that came with the computer has the fan in the back, and one on the bottom side aimed at the CPU. It slides into place, and then a plastic bracket snaps up behind it and holds it in place. The new one that I bought is too big, and the screw holes dont line up.
So....HELP!! No idea what I need to buy.
