Tom's Hardware > Forum > Homebuilt Systems > New System Build > cpu fan problem, computer failing to load
Forum Homebuilt Systems : New System Build - cpu fan problem, computer failing to load
hi guys, just built a new system here and running into a few problems
its a uBTX factor case and motherboard, and i believe my problem is either with the 4 pin connector for the thermal module or with its connection on the motherboard itself, as the computer boots fine when i plug the thermal module into a 3 pin fan connector but nothing comes up on the screen when i plug it into the 4 pin connector
problem is that i need to use the 4 pin to regulate fan speed as its way too loud otherwise
any help would be greatly appreciated
thanks
Sponsored Links
You can only plug the CPU fan to the CPU fan plug on the mobo, you cant plug it on to system fan or chasis fan.
Reply to roadrunner197069
- 0 +
it does work when i plug it into a chassis fan but not when i plug it into the cpu fan, which is where it should go - its just not ideal having it plugged into the wrong plug as like i said it wont regulate the fan speed
it did work once when i plugged it in there but i moved the machine and it didnt work again
Reply to indough
If you connect the CPU fan to any other fan power connector you're bound to have problems. The motherboard will not sense the speed of the fan, and may shut things down or create warning/error messages.
If you plug your CPU fan into the CPU fan plug, and things aren't working, there's likely something else going on that needs to be addressed.
When you say that "it didn't work again" what exactly do you mean? What happens, or does not happen?
------------------------------ Intel Q6600 G0 SLACR @ 3.2Ghz/ Xigmatek HDT-S1283 / XFX 680i LT SLI
2x MSI GTX 260 Core 216 (655Mhz) / 4GB Corsair XMS2 DDR2-6400 (800Mhz)
Antec TPQ-850 / Thermaltake Armor VA8003BWS
Win 7 Home Premium / 2 x WD Caviar Black 1TB / WD 400GB
Reply to jerreece
- 0 +
when i plug the 4 pin cable from the thermal module into the 4 pin connection, ie the cpu fan connection, the computer makes noises as though it were working but i get no video output on the monitor, on one occasion when i had the thermal module hooked up to the 4 pin cpu fan connection as described it did function normally, the fan speed was slower (as desired) and the computer booted just fine, but as soon as i switched it off and moved the machine to its location the computer wouldnt boot anymore
the only way i can get it working reasonably is to hook the thermal module up to a 3 pin chassis fan connection, when i do this everything is ok and im getting a cpu temp of around 30-32 degrees C
Reply to indough
Hmm, very odd. I'm tempted to suggest checking to make sure the CPU is seated properly. Just in case it is slightly loose and moving in/out of position as you connect/reconnect the fan power connector.
Other than that, short of having a mobo malfunction of some kind or the rare case of the fan itself not being compatible with your mobo, not sure what else to suggest.
If your CPU is running 30-32C you're doing good there. So the fan is adequate, though I assume it may run at 100% speed connected to a 3pin connector.
Still though, you may wish to try re-seating your CPU and seeing if that has any affect. Otherwise I'm sort of at a loss.
Reply to jerreece
- 0 +
yeah i figure its either got to be a problem with the fans connector or the place on the motherboard where it connects to, but i have no similar fan to try on it
i really cant use it with the fan at 100% as its loud as hell and the reason i built this is for audio applications haha its doing my head in
Reply to indough
There are 1147 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
