Tom's Hardware > Forum > CPU & Components > Sound Cards > Different Mediums for Sound Output
Forum CPU & Components : Sound Cards - Different Mediums for Sound Output
Is it possible to have music or a game's sound effects transmit through one's speakers while the sound of another program (Skype, Ventrilo, Teamspeak, etc) transmits through one's headset?
Also... is it possible to have sound of a program such as Ventrilo take precedence over another (music or a game's sound effects), effectively dimming out the other sounds?
For example...
I listen to music while talking on Ventrilo and wish for my music to go through my speakers and only the voices of my teammates through my headset.
Other times I wish for my music to simply dim out while a teammate speaks over Ventrilo.
Sponsored Links
Depends on what programs you have running. some programs will not use any other sound device other then the default sound device. I'm pretty sure that you can set ventrillo to a different sound device though. However you will need to have different sound cards. (I've only done it in windows vista)
As for the second scenario, I don't think that is possible. You would have to just keep the music dimmed the entire time.
Reply to PsyKhiqZero
If I have a sound card and an onboard sound device (Mobo), would that be sufficient?
Reply to TehFluent
agree with PsyKhiqZero
dicsrete and onboard is enough as suggested, the main issue is if the app you are using you are able to change the output device. I do this with Winamp as it provides this option
------------------------------ "This thread made me strap on my lolerskates and head for my roflcopter."
Reply to chookman
I utilize Winamp so that shouldn't be a problem.
So if I wanted to accomplish this, I would set music to transmit through my speakers in Winamp and then by default all other sounds would be transmitted through my headphones?
Reply to TehFluent
No set Windows default device to the sounds etc.
In winamp set to the music device.
Reply to chookman
There are 1405 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
