Spec
Type ATX Mid Tower
Color Black/Red
Case Material 0.6/0.8mm thick SECC
Power Supply 480w
Motherboard Compatibility 12" x 9.6" ATX
With Side Panel Window Yes
Expansion
External 5.25" Drive Bays 4
External 3.5" Drive Bays 2
Internal 3.5" Drive Bays 4
Expansion Slots 7
Front Ports
Front Ports 2 x USB, 2 x Audio
Cooling System
120mm Fans 1
Side Air duct No
Physical Spec
Dimensions 19.3" x 7.5" x 18.9"
i don't know the first thing about what im asking but i know that in order for me to get a better graphics card, i'm going to need at least 600w power supply.. my question is - can my motherboard hold a new power supply and if so what would be the maximum wattage i could buy for it
im 19 and i just want a computer that will play diablo III, starcraft II and counter strike source but im clueless about anything other than how to put a graphics card in a motherboard so all feedback is appreciated
Okay,
Any ATX (standard size) power supply will work with your computer case.
You don't need to upgrade your power supply if your a casual gamer like me. Instead look for a graphics card with no power connector on the back such as the Radeon HD 4670 which should be fast enough to play your games. Also, Diablo 3 is gonna be released late 2009-2010 so an upgrade now might not be advisable. However Diablo is designed to run on low-end hardware too! So, the current config should be fine.
