Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Geforce 9800GTX running at 65C idle & 97C load!?!?!?!
Forum Graphic & Displays : Graphics Cards - Geforce 9800GTX running at 65C idle & 97C load!?!?!?!
Iv just noticed my 9800GTX running at 97 degrees C after playing far cry 2 for 30 mins, im pretty sure this isnt normal. Is there anything i can do to get the temp to drop (except buying a new cooler).
Also, im using nVidia system monitor to check my temperatures, iv read that nv monitor sometimes displays the wrong info. Are there any other programs that will tell me the temperature of my GPU?
Sponsored Links
Gpuz, 2nd tab for "sensors."
http://www.techpowerup.com/gpuz/
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
Thanx for the program ;) but its showing the same temp as nv monitor, which is 64C idle. so i guess nv monitor was right earlier too when it was running at 97C :(
Reply to mrmoo232
This was a stale case. I retract my assistance as being a year later will no longer help this user.
Message edited by CiscoDude on 03-25-2009 at 03:15:42 AM
Reply to CiscoDude
There are 534 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
