Hi, im a noob who needs to build a good gaming computer for around $700. I dont know much about computers so i really need help.
my goal is to get a computer capable of playing upcoming games like Empire: Total War, and other graphically intensive games like Crysis or Oblivion. I dont need a new monitor or a keyboard or a mouse or stuff like that, im basically looking for 4 or 5 main components
Motherboard: no idea what i need here
Ram: again, no idea what specifically i need but i guess it should be 2 gigs
Processor: no idea what i need but i would like a core 2 duo, one thats good but not outrageously expensive. around $200 would be ideal
video card: i have a slight idea what i want because i heard that the Nvidia 9800 GTX is a good bang for my buck at around $200
Power Supply: this may not be necessary i dont know, my power supply is old and noisy but maybe it doesnt have enough juice to run these components. if you suggest a power supply, the cheaper the better because i know some of them can get expensive
That is bacically all i need i think, please any and all suggestions are welcome
I didnt pick out a power supply because i dont even know what to look for. How do you like these components? will they be able to run graphically intensive games at high settings? looking for input
There are plenty of articles about this, but here's a quick and dirty list, you pic the companies and parts:
P45 motherboard - $100-$150 or so E8400/E8500 CPU - $160-180 (if you are going cheap, check out the E7200, only $100) 2x2GB DDR2 800 RAM - low latency (Cas 4 or 5 and 1.8 v) (only ~ $50) 4850 for your GPU - great bang for the buck for around $150 Get a quality PSU - probably around 500w-600w (Corsair, PC power and cooling, OCZ, Antec) (less than $120) Western Digital 640 GB HDD - 2 platters - great performance and value. ($80)
Come back with a list of components and we'll take another look.
Good luck. We'll help again soon.
Message edited by huron on 09-28-2008 at 11:38:20 PM
i already made a list of components, check the post above yours
hmm, ok so you suggest for me to switch out the motherboard i picked for a p45 one, and you also suggest to get DDR2 ram instead of DDR3 ram? are you certain about that? isnt DDR3 more current and powerful?
interesting, so i will scratch out the GTX and will buy a GX2 instead
as for DDR3 vs DDR2, im confused, the GX2 video card says its for DDR3 and the p45 motherboard im gonna buy says its for DDR3, will i be able to use i if i only have DDR2 ram?
The 1gb ddr3 is video ram on the card itself. You can use whatever system ram you want.
DDR2 is the only way to go for system RAM right now. DDR3 will be used at some point in the future (Nehalem this Fall/Winter for sure), but is so expensive it is not worth it now.
The DDR3 is on the card, not for the system (just like the 4870 has DDR5).
The GX2 is a good card (like 2 9800 GTX SLIed on one card).
ok, i will take your advice, this will allow me to spend more on the video card and less on the ram so in the end it'll balance out and i should stay in my budget range
I will buy the 9800 gx2, i will buy the 2x2 DDR2 ram, i will buy a p45 motherboard in the $100-150 range, and i will stick with the core 2 duo e8500 since you guys didnt tell me to change that.
and with this set up do you think i will be able to run high end games like Empire Total War, Oblivion and Crysis at high settings?
Yes, you'll be able to run those at High.
Consider a q6600 quad instead of e8500. It overclocks well and quads are more futureproof for future multithreaded applications.
Yes, more games will be multi-threaded, but there is no such thing as "future-proofing." Certainly quads and more cores are the future, but the E8500 will be good for games now and for awhile into the future. The Q6600 is a great chip and does overclock well. That choice will be up to you.
