Solved
Help me select a Hard drive
I am building a lga 1156 system and am looking for a good hard drive.
Size: small - no greater than 500 Gb - no less than 80Gb
Speed: SATA 3.0Gb/s
Form: 3.5" internal
Budget: <$60.00
Raid: possible in the future
Basically i want a small and fast hard drive for not much money. I need a fast and reliable hard drive for not much money. I may have raid in the future
4 answers Last reply Best Answer
More about help select hard drive
  1. Best answer
    Hard Drives - Check out the performance charts and pick whatever 500 GB per platter drive performs best under your usage patterns. The 2 TB WD Black and LX from Seagate are good choice but at smaller capacities, you are limited to the Seagate 7200.12 or the Spinpoint F3. The 7200.12 excels in gaming, multimedia and pictures whereas the F3 wins at music and movie maker. See the comparisons here (copy past link in manually, link won't work in forum):
    (http://www.tomshardware.com/charts/2009-3.5-desktop-hard-drive-charts/compare,1006.html?prod[2371]=on∏[2770]=on)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148395 $55
  2. Best answer selected by kingofsales.
  3. pont said:
    did you not read my requirements???
Hard Drives NAS / RAID Storage Product
