Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Dual monitor using splitter cable?
Forum Graphic & Displays : Graphics Cards - Dual monitor using splitter cable?
Can anyone clue me in on whats required to run dual-monitor (using extended desktop on the 2nd) with the use of a VGA or DVI splitter cable from a single video output.
I assume the ability to do so requires a capable video card? If so, what is this feature called? Any cards in particular known to work for this?
------------------------------ Budget Build: Asus M2N-SLI Deluxe, Athlon 64 X2 @ 2.8 GHz, 2GB Mushkin DDR2, GeForce 8600 GTS, 250 GB SATA HDD, Thermaltake 430W PSU, Antec 900 case.
Sponsored Links
I'm typing on a computer with a DVI Splitter and 2 monitors and Radeon 2400 XT.
Works fine for office work. Not sure if the DVI splitter method works for gaming, etc. Otherwise use a video card with 2 ports.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
hey grndnatnl
while you can use a splitter to get dual-monitor with a graphics card that has one VGA/DVI, the result you'll get is the same identical screen on both monitors.
currently i do not know of any splitters that will give you the extended monitor feature from one output. you would have to get a video card that has two VGA or DVI outputs to get the extended 2nd monitor. most new cards these days come with 2 outputs, so it shouldn't be too hard to find. what's your price range? maybe me or another user can help you find the right range of card you're looking for.
there are however special cards that give you multiple monitors though they are quite expensive. these can give you 4 to 8 monitors but are quite expensive just in case you are curious.
here's the list i found on newegg for you.
http://www.newegg.com/Product/Prod [...] ame=matrox
good luck :)
Message edited by aznguy0028 on 10-24-2008 at 06:43:24 PM
------------------------------ http://valid.canardpc.com/cache/banner/590311.png
Reply to aznguy0028
I have extended screens with Dell DVI or VGA splitters.
They do not have the standard pinout, so only buy them for use with Dells.
Reply to evongugg
ah i see, good to know :)
Reply to aznguy0028
Matrox Graphics eXpansion Modules
Matrox DualHead2Go
Matrox TripleHead2Go
http://www.matrox.com/graphics/en/gxm/home.php
Reply to evongugg
Any idea/link where I can acquire one of these? Searched briefly but didnt come up with anything, nor on Dell's site.
The classroom here (at work) is set up with dell Optiplex boxes with a single-head video card and Y-splitters going to two dell monitors. Interesting thing is; some are all DVI, some are DVI to 2-VGA.
Thx, as I appreciate all the information, folks.
Message edited by grndnatnl on 10-24-2008 at 09:32:11 PM
Reply to grndnatnl
There are 779 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
