Tom's Hardware > Forum > Homebuilt Systems > New System Build > Sub $2000 system (everything), Now or wait? Build inside.
Forum Homebuilt Systems : New System Build - Sub $2000 system (everything), Now or wait? Build inside.
Hello.
I've been reading Tomshardware on and off for years, but never bothered to post because I haven't built a new computer in ages. I'm currently running a P4 2.4c 2gbDDR2 x1950agp. It's an old system, and I'm looking to upgrade towards the end of the year or the beginning of next year.
I'm not the kind of person who needs the latest technology, so I'm looking for a price/performance build that will just get me by for the next few years. The newest game I play is Warhammer Online, but other than that I normally only play games like Battlefield2 and Teamfortress2, not huge computer hogs. I don't play games like Crysis or do benchmarking or 3d editing. I am willing to do small overclocking if it is really worth it, but otherwise I try to stay away from overclocking because I live in northern California which can get pretty hot during the summers and really, I like a stable system that I do not have to play with constantly. I would be willing to do small changes to get free speed sure, but I'm not looking at pushing the system.
There are a few brands I am in love with, Gigabyte for Motherboards and Lian-li for Cases, and would prefer to use those for the motherboard and case over any others. I own two computers with Lian-Li (one Mid one Full tower) and have told myself I will never buy another brand of computer case. Also I try to stay away from Asus or brands that have bad return policies or websites that are barely readable in common english. This is a price / performance build with no real hard cap on budget, but I would like to keep it in the $1500-$2000 dollar range while still using quality components.
[Case] Lian-Li PC60BPlusII
http://www.newegg.com/Product/Prod [...] 6811112100
[Mobo] Gigabyte GA-EP45-DS3R Crossfire Ready Motherboard
http://www.newegg.com/Product/Prod [...] 6813128344
[CPU] Intel Core2 Duo E8500 3.16
http://www.newegg.com/Product/Prod [...] 6819115036
[RAM] 8gb (4x 2gb) Corsair DDR2 800 Dual Channel
http://www.newegg.com/Product/Prod [...] 6820145184
[HDD] Seagate Barracuda 7200.11 500gb 32meg Cache
http://www.newegg.com/Product/Prod [...] 6822148288
[PSU] PC Power & Cooling S75QB 750W ATX12V / EPS12V Crossfire Ready
http://www.newegg.com/Product/Prod [...] 6817703009
[GPU] POWERCOLOR AX4870 1GBD5-PPH Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported
http://www.newegg.com/Product/Prod [...] 6814131120
[Audio] M-Audio Revolution 5.1 192kHz PCI
http://www.newegg.com/Product/Prod [...] 6829121122
[Monitor] ASUS VK222H Black 22" 2 ms HDMI Ready
http://www.newegg.com/Product/Prod [...] 6824236043
[Keyboard] Logitech G15 2-Tone
http://www.newegg.com/Product/Prod [...] 6823126034
(note: I listed the G15 2-Tone but actually plan on purchasing the model #967599-0403 G15 from previous years. It has 18 G keys while the new G15 only has 6. Will be an eBay purchase more likely.)
[Mouse] RAZER Diamondback 3G Earth Green 7 Buttons 1 x Wheel USB 3G infrared Gaming Mouse
http://www.newegg.com/Product/Prod [...] 6826153028
[OS] MS Vista Ultimate 64bit SP1 System Builders OEM
http://www.newegg.com/Product/Prod [...] 6832116493
[NIC] EDIMAX EW-7128G PCI Wireless Card
http://www.newegg.com/Product/Prod [...] 6833315041
[MISC] LG 20X DVD±R DVD Burner w/ SecurDisc Tech Black SATA Model
http://www.newegg.com/Product/Prod [...] 6827136149
[MISC] eDimensional AudioFX 5.1 Headphones USB
http://www.newegg.com/Product/Prod [...] 6826504004
[MISC] OCZ OCZTFRZTC Freeze Extreme Thermal Conductivity Compound
http://www.newegg.com/Product/Prod [...] 6835202006
[MISC] ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler
http://www.newegg.com/Product/Prod [...] 6835186134
[MISC] 2x Evercool 80mm x 80mm x 15mm Case Fans (slim 15mm)
http://www.newegg.com/Product/Prod [...] 6835119041
[MISC] 2x Scythe SY1225SL12L 120mm "Slipstream" Case Fan
http://www.newegg.com/Product/Prod [...] 6835185057
[MISC] XTRAC Ripper Optical Mouse pad
http://www.newegg.com/Product/Prod [...] 6817114174
Total Price: $1,920.77. This is a fine number to be at, I just want to make sure everything is going to be working flawlessly together (I don't know much about CPU / Ram settings in BIOS).
Thanks ahead of time guys.
Message edited by projhex on 10-02-2008 at 02:49:50 AM
Sponsored Links
save some money and get these:
http://www.newegg.com/Product/Prod [...] 6817703005 (psu)
http://www.newegg.com/Product/Prod [...] 6814130338 (gpu)
or get this mobo
http://www.newegg.com/Product/Prod [...] 6813157136 (mobo)
and get 2 of these.
http://www.newegg.com/Product/Prod [...] 6814261027 (gpu)
in my opinion i would go with the 4850 cf.
update: my apologize that is a cf board. i would just get 2 4850 instead of the 9800gt.
Message quoted 1 times
Message edited by invisik on 09-29-2008 at 12:54:26 AM
------------------------------ intel core 2 quad q6600 @3.2ghz msi p6n diamond (X-FI Extreme sound) 6gig of OCZ+CoRSAIR oc 900mhz Nvidia gtx 260 sli @ 730/1465/1250
Lite-On Blue-ray Western Digital 7200rpm 500gb Antec 500 Earthwatt Window vista 64-bit
Reply to invisik
so overall a great build but i do have a few notes
first and most important that is a CF board and a SLI setup the video cards don't work....
i would pick 2 4850s they have HDMI out aswell. also the HDMI on those boards can send sound. Nvidia's doesn't to my knowledge.
i would keep the 750watt
you should be able to fit all the expansion cards in the case
you could look at a little bigger case 2 dual slot GPUs takes alot of room
i am for the Gigabyte motherboard
if you want to save some cash this is how i would do it: drop the sound card, drop a GPU, and try and find a keyboard laying around. those are tough things to do but they can save you 300ish bucks
hope this helps, like the rig, and good luck
Reply to rammar16
- 0 +
Is that Palit brand something that is trustworthy? It has 8 reviews and I've never heard of the company. Also those are 512meg DDR3 cards, are they really better than the 1gb 8800GTs? I looked at the Q3 charts for video cards and really on the level they are running these things there seems to be not much difference in what I would use it for i guess.
I could drop the sound card if really needed, the mobo does have 7.1 channel on it. I've always just been a fan of MAudio because they run 192KHZ cards which have superior range of sound to creative cards. They keyboard I don't mind purchasing because the G15 really helps out when you're using programs like Ventrillo because it is capable of displaying peoples names who are talking, and in games I play such as Warhammer that can make a difference when 10 people are all trying to talk at once. Also the macros are nice for games.
Do you really think swapping over to a single 4850 512mb is worth it from dual 1gb 8800gts? I realize that not a lot of games really utilize the Crossfire / SLI setup, but games in the future will and it seems smart to just buy two of the same cards so I don't have issues down the road.
Thanks both of you for the quick replies.
Reply to projhex
I agree with what invisik said about the PSU, just go with the 610w one. Nice choice of brand though, Pc Power and Cooling are really really nice psu's. Nice case too.
As for the Motherboard, nice choice also. Its an intel chipset though, so you would want to go with an AMD video card. I say go with 1 4870 that has a upgraded cooler. Somthing like this:
(note: 1gb)
And do you really need a sound card?
------------------------------ Gigabyte GA-P35-DS3L*Intel E2180 OC 3.00Ghz Lapped*PowerColor ATI 3850 256MB*Patriot 2x1GB DDR2 800*Cooler Master CM690*Western Digital 250 GB*Silverstone Strider 600 Watt Modular PSU*Samsung Lightscribe Drive*CoolerMaster Geminni II Lapped Mirror Finish
Reply to SuicideSilence
- 0 +
(note: 1gb)
I guess that is the question right now. Do I do dual 4850 512mb or single 4870 1gb. I guess they cost about the same. Last time I spent $300+ on a single video card though was my GEForce 3 Ti500 (/sigh).
And the sound card. Looks like something that might be scrapped. It's not in stock anyways and hasn't been for some time.
Reply to projhex
Yea unless your going to be using really nice speakers that can take advantage of the sound being output from your sounds card, its not really worth it.
Some games wont even take advantage of Crossfire. I say 1 4870. Any more questions?
- 0 +
The Dual HD 4850 will be undoubtedly superior than a single HD 4870, if you're going that route, then get the Silencer 750W just to be safe.
I am a friend of sound cards and if you're like me and actually care about sound, then I'll recommend it, even though a lot of the folk here think onboard audio is "good enough", if you like quality, then go for it and don't let anyone else tell you otherwise.
I have the Logitech X-530 speakers (Basically differently packaged X-540, without the controller) and combined with my X-Fi, they sound pretty well (I know I could get better speakers, but these were very good for what I paid).
If you're open to it, I would suggest more recent mice with newer sensors, the Mx518 is a decent mouse, however it shows it's age compared to newer ones.
RAZER Diamondback 3G Earth Green 7 Buttons 1 x Wheel USB 3G infrared 1800 dpi Gaming Mouse - Retail
RAZER RZ01-00150100 Black 5 Buttons 1 x Wheel USB Optical 1800 dpi DeathAdder High Precision Gaming Mouse - Retail
http://www.newegg.com/Product/Prod [...] 6826153024
------------------------------ Anxiously awaiting the Hydra 100 and the Hydra Engine...
www.lucidlogix.com
Reply to emp
- 0 +
Thanks for the suggestions on the mouse. I just picked the logitech one because 1) it matches the keyboard and 2) i figure they know what they are doing.
I'm currently using a Microsoft Habu http://www.newegg.com/Product/Prod [...] oft%20habu which works fine for what I do with it, however I will not be parting out my old PC as I want to keep it together for use. Honestly I would probably be fine with a 1980's ball mouse but I guess there is no reason not to get something better.
Reply to projhex
- 0 +
If you like the Habu, you should know that it was designed by Razer, but distributed by Microsoft. The Diamondback 3G and DeathAdder both use the newer 3G laser sensor (Even though there's a typo on the newegg page stating that the DeathAdder is optical, but in reality the DeathAdder is only available as a Laser mouse).
I use the Diamondback 3G myself, but some people might find the DeathAdder's shape a little better for their hands, it's really personal preference at this point.
www.lucidlogix.com
Reply to emp
- 0 +
Thanks again for the replies above guys.
I edited the OP to reflect the suggestions made and from further research. I still have a few questions however.
First, I've read that the Lian-Li cases with the top 80mm fan can have clearance issues with the PSU and was wondering if anyone actually owns one of these cases and can tell me whether or not they have any issues and what PSU they are running.
Second, I added the ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler and was also wondering if anyone has this setup in their Lian-Li and if they had issues. I think after removing the PSU pipe that is supplied with the case there will not be too much problem, but would like to know if someone has this setup.
Thanks again guys.
Reply to projhex
There are 502 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
