Help experts: Yellow question marks in Device Manager
Help experts: Yellow question marks in Device Manager: Intel H67 SandyBridge chipset (DH67CL motherboard) with Windows XP
I have used an an Intel DH67CL Sandy Bridge "6 Series" H67 Chipset motherboard, to serve as an upgrage for an old Intel D845WN PC running Win XP SP2, and did an XP "repair installation" by the book.
All in all the installation went pretty well (I had to change BIOS configuration from AHCI to IDE, though). The repair installation goes through a new "Hardware Enumeration" and updates the HAL. Then I loaded some of the new drivers from the mobo driver CD.
The problem is now, when the PC boots it says: "New Hardware Found", but it can't find the driver (nor can it be found in "updates"), and when I open Device Manager and look for missing drivers (so-called: "other devices"), there are three yellow question marks (which stand for missing or bad drivers):
1. "Audio Device on High Definition Audio Bus": "VEN 8086 DEV 2805". (Vendor 8086 is Intel. 2805 must be about the chipset). I can't find "DEV 2805" on the Net. (Sound/audio are working fine, BTW).
2. "Unknown Device": "VEN 8086 DEV 0102". Vendor 8086 is Intel again. I found this: "Intel SandyBridge HD graphics" at the "driverskit dot com" site, but I don't want to install their "driver locator software" - I suspect spyware/malware.
3. "Unknown Device": "VEN 1095 DEV 0680". This is a Dynamode Silicon Image IDE/ATA PCI storage controller card, for which I have installed the driver and it's working fine (including IDE disk access). I don't understand why it's showing as a missing driver.
Can you help with finding/installing the drivers? Your help will be appreciated. By the way, I have updated the mobo BIOS - it's up to date.
Thank In Advance - Gail H
2 answers Last reply
More about help experts yellow question marks device manager
  1. First suggestion, update to SP3.
    Get the BIOS update, then the Chipset drivers from here:
    Then get the rest of the drivers for Audio, Video, etc...
    The HD Audio shuld be fixed with XP SP3 and the drivers from above.
  2. hang-the-9: I think I've basically done what you suggested, and it worked:
    1. First, I backed up the C: drive, made an image using CloneZilla. (Good tool, terrible user interface, + doesn't have yet NIC drivers for Intel Sandy Bridge).
    2. Installed the WinXP SP3 upgrade.
    3. In "Device Manager", I right-clicked the yellow sign for the missing driver for the Dynamode Silicon Image IDE storage controller, using their supplied CD. This time the system accepted the file and loaded the driver.
    4. I then found at the Intel web site (couldn't find before) and downloaded an installation file for both the HD video and audio bus of the "6-Series" H67 chipset, and installed it - it went fine. Vendor 8086 (Intel), products 2805 and 0102. Interestingly, Google didn't find it, I found it on Bing.
    Thank you for your good suggestion.
Drivers Device Manager Sandy Bridge Intel Windows XP
