Tom's Hardware > Forum > Homebuilt Systems > New System Build > (New System Build) Sorry to cliche/passe (please help)
Forum Homebuilt Systems : New System Build - (New System Build) Sorry to cliche/passe (please help)
This is my first time building a computer and am a little lost. I've been reading a bunch of literature on the topic and have replaced almost all the parts in computers many times. However I knew all those parts went with each other. However making one on your own has the drawback of not knowing all these parts work together. So I was wondering if someone could help enlighten me as to the art of building or anything I should read. This is the current build of the system, I have Vista x64 Home Premium and a 500gb HD with a 16mb cache. Anyone who could please tell me if this will work and if it's good I would greatly appreciate the help. :hello:
http://secure.newegg.com/WishList/ [...] r=13060147
Sponsored Links
Nice... for a little more you can get a Q9550, which should overclock better and run cooler. Not to mention that is actually in stock at the moment.
Intel Core 2 Quad Q9550 Yorkfield 2.83GHz 12MB L2 Cache LGA 775 95W Quad-Core Processor - Retail
http://www.newegg.com/Product/Prod [...] 6819115041
------------------------------ Anxiously awaiting the Hydra 100 and the Hydra Engine...
www.lucidlogix.com
Reply to emp
- 0 +
Oh...my apologies, I forgot to mention the budget. It's only $1100. I already got the CPU, I just put it in there to show that it's part of the system (There was an awesome deal for the Q6700 for $210)
Reply to SirRob
- 0 +
Nice, but you're still missing a GPU, I would suggest at the very least an HD 4850.
www.lucidlogix.com
Reply to emp
- 0 +
I think you should go with Dual HD 4850s, given the fact your board is limited to x8/x8, if you crossfire HD 4870s the bandwidth limitations will show greater loss compared to HD 4850. Add to that the fact that you can get 2 HD 4850s for $340 before rebates.
www.lucidlogix.com
Reply to emp
- 0 +
Well I'd rather change the motherboard than the GPU. Since for Xmas my parents said they'd match my GPU with the same.
Like this Mobo
http://www.newegg.com/Product/Prod [...] 6813186148
Can't tell if it supports Xfire though.
Reply to SirRob
- 0 +
x8/x8 is a limitation on the P45 chipset, you'd need to get an X38 board in order not to be limited by it.
DFI LANPARTY DK X38-T2R LGA 775 Intel X38 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6813136045
www.lucidlogix.com
Reply to emp
- 0 +
the X48 set work the same or just the X38?
Reply to SirRob
- 0 +
The X48 is basically a higher binned X38 chip, so don't bother with them, since an X38 can do 98% of what the X48 can do at $100 less (and that really only applies to overclocking). Both will give you the x16/x16 bandwidth required for HD 4870 crossfire.
Message edited by emp on 09-29-2008 at 06:37:25 AM
www.lucidlogix.com
Reply to emp
- 0 +
Thank you. So much to learn still. This is very troubling. Do you know of any literature that would give me a broad knowledge of this all?
Reply to SirRob
- 0 +
Here are some tests (Even though these are on early 8.6 catalyst, but it's just to give you an idea of the x8/x8 limitations, which will be greater when using HD 4870s)
http://www.tweaktown.com/articles/ [...] index.html
www.lucidlogix.com
Reply to emp
- 0 +
I can't seem to find any mobo's that have x16/x16 and are for a decent price <$150.
Reply to SirRob
- 0 +
That's because there are none for intel platforms. Only AMD boards would be that cheap and still offer x16/x16 crossfire performance.
www.lucidlogix.com
Reply to emp
- 0 +
Well then I'll buy a mediocre board for now and wait till either xmas or easter and get a new board that supports it.
Reply to SirRob
There are 519 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
