Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Need advice on my next build
I'm putting together a new build and I'm not really sure what I'm doing. I mostly browsed through threads trying to put together what I prefer, and here's what I have so far:
===case=== $79.99
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Prod [...] 6811119137
===ram=== $62.99
mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
http://www.newegg.com/Product/Prod [...] 6820146731
===GPU=== $273.98
Radeon HD4870
http://www.tigerdirect.com/applica [...] VqHCjCdwwp
===Mobo=== $119.99
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6813131299
===Cooling=== $36.99 + $6.99
Cooler - XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
http://www.newegg.com/Product/Prod [...] 6835233003
Retention bracket - http://www.newegg.com/Product/Prod [...] 6835233019
===CPU=== $324.99
Intel Q9550
http://www.newegg.com/Product/Prod [...] _-19115041
===HDD=== $67.99
Western Digital Caviar SE WD5000AAJS 500GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Prod [...] 6822136178
===Disk Drive=== $29.99
LITE-ON Black 20X DVD+R
http://www.newegg.com/Product/Prod [...] 6827106265
Also I'm still missing a PSU, does anyone have a good recommendation to go with what I have?
Thanks!
Sponsored Links
Corsair or Thermaltake. At least 550W.
BTW, what are you building the rig to do primarily? If it's gaming, I'd say you're overcompensating on the CPU.
Anyway, good luck with the build.
Reply to kitsilencer
- 1 +
On the hard drive might wanna check out the wd640
http://www.newegg.com/Product/Prod [...] 6822136218
Thats the flavor of the month (well last couple of months) as far as hard drives go.
And for the gpu I would get the same card but made by visiontek
http://www.newegg.com/Product/Prod [...] 6814129113
Diamond has a meh reputation, and a terrible warranty.
and heres a solid power supply from one of the better reputation makers
http://www.newegg.com/Product/Prod [...] 6817703005
Reply to dcm1602
I think it's a good build as is.
Corsair 650TX would be a great match... more power than you need, but that just gives you some longevity and ensures it will run cool and quiet for years to come:
http://www.newegg.com/Product/Prod [...] 6817139005
The Case is OK, but for the money the Antec 300 is better:
http://www.newegg.com/Product/Prod [...] ntec%20300
If you want to save a little, the Antec 650W that comes in a combo deal with the case is NOT as good as the Corsair, but it IS adequate.
The WD 500 AAJS is not a great choice for speed. The 640 AAKS would be a better choice if you can swing it.
Your CPU is fine. Adequate speeds in non-multithreaded games and programs and a screamer in places that can use the extra cores. Yes you will not use the extra cores much today, but that is the direction things are going. Next gen Intel will have even more cores ;)
don't forget the thermal paste.
Reply to Proximon
- 0 +
Thanks for the help!
I'm using the rig primarily for gaming. I know that quad core chips won't be utilized for the most part, but I do a lot of multitasking (compiling a programming project in the background while gaming while browsing the web, etc.) so I'm not too concerned.
The power supply linked by dcm looks like a good deal but I think I'd rather go with a corsair PSU.
As for the hard drive, case, and GPU, I'll make those changes. Thanks again!
Reply to Kaezin
There are 1293 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
