GA-EP45-UD3R and 2x2GB G.Skill PC-8500 DDR2-1066 dual-channel problem
Hey folks - I've done some searching and reading and found people with similar issues as me but no solutions yet.
I'm running an Intel E8400 Core2 on my new Gigabyte GA-EP45-UD3R motherboard with 2 sticks of 2GB G.Skill F2-8500CL5D-4GBPK memory.
The system will run stable with the memory clocked to its default 1066Mhz and installed in single-channel. It will also run stable clocked to 800Mhz and installed dual-channel. It will NOT however run stably locked to 1066Mhz and installed dual-channel. With the system doesn't get past the beep (no access to BIOS or anything until I remove a stick).
I have tried manually increasing the DRAM voltage to 2.1V to no avail.
Anyone have any other suggestions? Is it likely memory or mobo related?
I can provide more info if needed... Thanks so much; it's driving me crazy.
Did you try to increase the MCH Core Voltage ?
It seems to be recommended for memory modules of more than 1 GB.
MCH/ICH
MCH Core…………….....1.100V...........: 1.200V
MCH Reference….…….0.760V...........: Auto
MCH/DRAM Ref.…......0.900V...........: Auto
ICH I/O……………….....1.500V............: Auto
DRAM
DRAM Voltage ……....1.800V............: 2.100V
Hope it helps, Hervé
Ask the community
