Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help me make a Decent System?
Forum Homebuilt Systems : New System Build - Help me make a Decent System?
I have a few Ideas...Trying to Keep this under $500..the cheaper the better..
Looking for a Reliable System to grow into...and Eventually OC..not right away..I play WoW, and surf the net...
Current Setup:
Asus A8N32-Deluxe(I believe something is wrong with it, dont ask why..)
AMD 64x2 4200+
2G Ram
GeForce 7600GT - Will Re-Use.
I just need suggestions, or setup ideas...Ill post my Ideas, and let you guys go from there..
Im clueless about what RAM, and whats the best for each idea...if you have a completley different suggestion, feel free...
My AMD Idea...
I would like to run 4G Ram, and Windows Vista 32-Bit.
The Processor I was looking at - http://www.newegg.com/Product/Prod [...] 6819103289
The MOBO for it -http://www.newegg.com/Product/Prod [...] 6813141011
My Intel Idea (A bit on the pricey side for what im wanting to spend, but I think its overall better)
***Picture of my Shopping Cart Idea***
http://i451.photobucket.com/albums [...] titled.jpg
Sponsored Links
Crap psu in the photo.
Is WoW lagging on your pc? I don't mean when you're alone walking around, I mean when there's a 50-men raid. :D
I don't think anything is wrong with the mobo, but some boards are unstable even with stock settings. They have to be fine-tuned both in BIOS & Windows.
Out of the 2, the Intel build will overclock very well. Look for a Xigmatek cooler.
XIGMATEK ACK-I7751 Retention Bracket - Retail
Reply to auscanzukus
There are 887 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
