Solved
Voltage Problems
  • Motherboards
  • Overclocking
  • CPUs
January 9, 2010 9:32:19 PM
I am overclock my PII 940, i got to 3.6 ghz with the voltage on auto, but i cant go any higher without major unstability. So when i go into the cpu voltage options, my lowest choice is 1.55V. I'm almost positive that is way too high. What can I do?
More about : voltage problems
Best solution
a c 304 V Motherboard
a c 296 K Overclocking
a c 162 à CPUs
January 10, 2010 12:14:38 AM
Hi men. It's a good OC for the 940. The recomended voltage for AMD processor isn't more that 1.5V, so, in your case you can set to 1.55V but is dangerous for your processor, my advice is that not set the 1.55V.
January 10, 2010 12:21:23 AM
Yea, but thats my lowest choice, that or auto. so i wont be able to OC it anymore?
m
l
a c 162 à CPUs
January 10, 2010 12:28:15 AM
For now left the voltage on auto, update the BIOS of your mobo and try again.
m
l
January 10, 2010 12:31:36 AM
um, i think i updated it sort of recently but ill check.
edit: yea i have the latest.
m
l
a c 162 à CPUs
January 10, 2010 12:54:09 AM
That's strange. Does you try with the evga support?
m
l
January 10, 2010 1:15:23 AM
I dont want to fill in 40 boxes of information just to sign up and send them an email hehe
m
l
a c 162 à CPUs
January 10, 2010 11:24:25 PM
^jejeje, good reason, sometimes i do the same, but in this case could be necessary that you do.
m
l
January 11, 2010 11:58:57 PM
Eh, i'll be happy with the OC that i have now. I'd rather leave my computer alone when it's working well.
m
l
a c 162 à CPUs
January 12, 2010 12:07:09 AM
Ok, and any another question don't be afraid to ask me.
m
l
