External hard drive not detected (XP) Help!
After dropping my Iomega 1TB external drive it made a strange clicking/beeping sound everytime I switched it on. At first i thought it might be the usual 'Click of death' but the beeping sounds are periodical. As a last resort I tried taking the case off and stuck the hard drive in the freezer for 2 hours.
When I took it out and plugged it in it still made the beeping sounds even after I gave it a little tap. I left it switched on for a while (plugged in to laptop via USB) and the beeping stopped, a while later the device drivers were installed. Although the drivers are installed windows cant detect the device and so I cant recover my precious data!
Any help is much appreciated, Thanks.
1 answer Last reply
More about external hard drive detected help
  1. once you dropped your HDD on ground they you have DROP your idea to use it for ever..
    check if there's replacement available ..
Hard Drives External Drive External Hard Drive Windows XP Storage
