OK so i just joined and was wondering if you guys could help me.
I am looking to buy or build a gaming desktop for 600-700 dollars (b4 tax). I realize that this is not a huge budget, but it's what I've got to work with.
So what do u guys think i shud get? Keep in mind that I am in Canada, so if all prices could be in Canadian dollars, from a Canadian site, it would be great.
I was thinking of buying a ~$400 system from futureshop, and buying maybe an 8800 gt to upgrade. I may also need to buy a new psu.
here is the link for the type of thing i was thinking of. there are a few different options here:
PS: I dont really know much about power requirements. I know it doesnt say what psu these boxes have, but prob ~300W. Would an 8800GT run on that? Also on the phenom one, i could (and would) take out the 8500 gt......would this free up enuff power to runa better card (ie. 8800 gt??)
Finally, I can get a 9800 gtx+ for 190$. If this would work with the budget, it would be great (unless the processor would drag it down so as to not give great performance anyways)
sryy...finally, keep in mind that i do not plan to upgrade this computer...i will only be using it for a round a year.
Message edited by smart1002 on 10-01-2008 at 01:13:05 AM
ok thanx...i am definitely willing to build a comp and would love the experience...i just thought that buying and upgrading would be cheaper at this price bracket...so can you give me some links to parts that u would recommend for my build?
Also, the 9800GTX+ would have been badly bottlenecked by those CPUs.. this one would do the job. Possibly we could upgrade you to an E8400 as well, once we see how your prices go.
Those are nice systems, so long as you keep the upgrades to a minimum.
The BIOS is locked, so you will not be able to OC.
The result is you are going to have limited performance.
You will also need to replace the PSU as you noted.
Once NewEgg.CA is up, try and build a system and then compare.
If you are looking for a simple system and light gaming, then one of the HP systems may work. But if you really want to do more, you will need get a significantly better system.
------------------------------If its good in theory but not in practice,
its not good theory.
Reply to zenmaster
thats a killer rig for $750 i know it is a little over but the 4850 will crush that 8800gt if you want to save a bit the best way is to get a 9800GT and the 450watt PSU but personally i would leave that build alone
honestly tho as long as you don't buy the two pre-built systems listed up top i will be happy
good luck and hope this helps(sorry all the stuff is US pricing)
Message edited by rammar16 on 10-01-2008 at 04:16:48 AM
alright thanx a lot. checking some of the products, it seems that you took the prices b4 rebates, so that's an extra 100 dollars off! sweet! and as far as an OS goes, I have a windows xp home disk that i could use. Im kinda scared of vista, and i believe that it is for good reason. I like newegg, not that ive ever used it, but it seems that most of the shipping is free. even with converting to canadian dollars, it seems that this build would be around 700 bucks, which is perfect. and ya maybe i would upgrade to the e8400. looks good guys! i'll wait till the first to see gow the canadian newegg looks, what the prices are like etc. btw, if anyone cares i am hoping to play crysis warhead, assassin's creed, prob gta4 when it comes out in november for pc...thanx!
ok so now that newegg canada is up and running, we can get on with getting me this beasty! I'm going to work on my own build and post it for review, or if you want you could just post some components. on the other hand, maybe i'll just try to find the original component (from .com) on .ca
ok kool ive added evrything to a cart and with taxes and shipping it comes out to just over $800, which should be fine. a couple more questions:
a) I have a cd for windows xp home edition sp1. it has been installed on another comp (the one that this build will be replacing). will i be able to install this os, and will it be fine? can i run dx10? i heard i could with a hack
b) is that video card (the 4850) fine? it isnt the same manufacturer that you first suggested, but it was the cheapest.
a) You cannot have the OS on both systems at once, legally. When you validate, MS will log the change in systems. You need to validate to get updates, and if you don't XP will stop working after 30 days.
I'm not aware of any DX10 hacks, but it makes no difference. I see a few things in DX10 that you sort of notice, like reflections off your gun barrel in Crysis... but nothing to get too excited about. You can install Vista 64 later, when you can afford it.
b) Yes pretty much all ATI makers are good. You won't get as good a warranty with Sapphire (2 year), as you would with Visiontek (lifetime).
All the above suggestions are valid, but depending on where you live, you might have PST on top of GST depending on what website you buy off from. I just recently helped a friend built his comp (he lives in ON), that's why I know about these nitty-gritty details.
DirectCanada and Newegg.ca are where I would look first (DirectCanada's web layout sucks, but the prices are right and they only charge PST in BC). NCIX has some good deals occasionally, but I wouldn't count on it (they're usually more expensive).
------------------------------"If you don't plan on listening, why ask?"
Reply to johnyeah
