New Power Supply
Hello,
I'm going to be putting together a new computer and wasn't sure if this power supply would be good or not 12v?
Rosewill RP600V2-S-SL-S 600W ATX12V v2.01 SLI Certified CrossFire Ready Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182062
The power supply will be for a:
EVGA 132-BL-E758-A1 LGA 1366 Intel X58 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188039
Intel Core i7 920 Nehalem 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
G.SKILL 3GB (3 x 1GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Triple Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231229
Western Digital Caviar Blue WD800JD 80GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822135106
Western Digital Caviar Black WD5001AALS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136320
LG 20X DVD±R DVD Burner w/ SecurDisc Tech Black SATA Model GH20NS15 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136149
and CF
HIS Hightech H485F512P Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161235
Thanks for your answers, Sean
3 answers Last reply
More about power supply
  1. Avoid the Rosewill power supply. Their not very good and definitely not recommended. Instead get a high end psu for your new system. Take a look at Corsair and PC Power and Cooling.
  2. i say get the corsair 600w modular power supply
  3. Get an enermax, corsair or silverstne IMO, 600w Plus. and you are good
Power Supplies Components Product
