Hi, i was looking at my armor+lcs case and it looks like you can put a 120mm fan on the top, but i couldnt find a way to attach it to the grill, any ideas?
I went to the ThermalTake web site to take a look at the case. I did not find a photo of the top of the case. Looking a a side view of the interior it does appear as if you might be able to mount a fan to the top panel.
Is the top panel perforated? Perhaps you could simply use screws to fasten a fan to the top panel.
When I do case mods I usually drill blowholes in top panels and drill holes for the mounting screws.
Armor LCS has HDD compartment and PSU compartment on top where the perforated area is. YOU CAN NOT install a fan there. Why would you need a fan there? The PSU fan is enough for that area.
